Hay Making on a Different Scale
   / Hay Making on a Different Scale #341
It qualifies as a REAL farm eruck now.... Ran my discbine into a fence post and bent the side shield on the right side trying to get all the forage cut, From here in out I'll stay a foot off the fence line. That side shield is over 500 bucks at NH. This winter I'll take it off and maybe repair it with some hillbilly bodywork.
I asume the corroded rim is from running CACL, correct? Something I never do. CACL is planned obsolence. Got 35 4x5 tight wrapped bales of the little piece I'm doing now, I was surprised. Got it off, parked the bales on the headlands and sprayed the field with my usual DEF and water mix to get the alfalfa growing well for possibley a September-October cut if the weather cooperates.
I need to change the knives on the disc bine as well as hardface the skid shoes. Best price I've found for the serrated cutter knives I use is Shoup. About 1/4th of the NH price. Same knife as well. I'll probably change the gear oil in the cutter bar as well. The sandy loam we are on plays heck on anyrhing ground contact.
My customer will drop off a trailer, I'll load them and away they go.
   / Hay Making on a Different Scale #342
Finally getting things done................though slowly................and not with issues. Busy week and weekend if no rain.
View attachment 3712261View attachment 3712262
What happened to the cab interior?
Sorry to hear about the truck. You have been having a terrible year, the weather, the equipment issues. I know its easy to say but don't let it get you down. I hope things get better for you!
Raccoon came up through the battery access door during the winter.
50 acres done. Only 120 more for dry plus all the baleage we have yet to do. Round baler is now down indefinitely. Neighbor baled up my rounds with his Krone. 172 4x4 round bales and 1222 small squares. Today is load out for rounds.
   / Hay Making on a Different Scale #346
Europe has long been manufacturing hay equipment and a way of life for so many family dairy farms…
   / Hay Making on a Different Scale #347
What happened to your round baler that will take it out of commission that long?
Tensioning system went somewhere. Working on troubleshooting in free time. The easiest fix did not work. Replacing the pressure relief valve. Just narrowed down where to look next. Leaning toward the belt tension cylinder. Ran some tests and waiting on what to do next. Then just need time to fix. Ordered tech manual. It was time. Blowing hydraulic oil points to an issue. Several components just a process to troubleshoot.
   / Hay Making on a Different Scale #349
Curious as to what make of round baler and if it's a NH, I have the adapter as well as the liquid filled gage to check the bailing pressure if you want it, I can send it to you. When I traded the NH for the Kubota, the gage and adapter stayed here. Let me know and you can have it as I have no use for it anymore. The Kubota has the built into the running gear, both the gage as well as the electronic servo to control the pressure. Again, you have my physical address and phone number. Just taking up room in the tool chest now. I believe I also have the pertinent instructions for setting the tension cylinder as well. Never had to but was prepared anyway.
If I remember correctly, the NH had one cylinder whereas the Kubota has 2, one on each side of the bale chamber completely under the side shrouds, never to be seen, unlike the NH.
   / Hay Making on a Different Scale #350
Good to have neighbors will to help. I don't have that here as my neighbore are all row croppers or truck farmers and while I have the prime movers available, I have no extra hay tools available.
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
JOHN DEERE 6615D MFWD TRACTOR (A52708)
JOHN DEERE 6615D...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
43055 (A55851)
43055 (A55851)
