Hay Making on a Different Scale
/ Hay Making on a Different Scale #401
Another round of 2nd cutting done. Very poor yield even with fertilizer. Just a crappy year all around. Still picking off first cutting. Customer orders are filled. Sales are down again. Making some baleage with it to feed this winter and get some rounds and squares in the barn to sell. We went from wet and no weather to make hay to hot and dry. Then comfortable and dry. We are currently in the middle of a 10 plus day dry spell. Yields are going to suffer.
View attachment 3857818View attachment 3857819View attachment 3857820View attachment 3857821View attachment 3857822
Getting tired of all these smoke events. Seems to happen way to often and used to be a fall issue. Now it is late spring and late summer/fall
View attachment 3857823View attachment 3857824View attachment 3857825View attachment 3857826View attachment 3857827View attachment 3857828
Somewhere I read that the first thing a farmer must have is hope. How very true.
/ Hay Making on a Different Scale #402
If you aren't an eternal optimist, you can't last in farming. You also need a good wife and help thats willing to work odd hours along with you.
Buncha money aint bad to have, either
Some more from past week at picking away 1st cutting.
Finally the last of the first cutting in these fields. Only 50 more acres to go LOL
/ Hay Making on a Different Scale #404
We used to have an Arab and a quarter horse studs. We long ago quit breeding for a variety of reasons. Like dogs and cats, there are too many unwanted horses, people that had no idea what they were getting into, and expenses. Vets coming out of school that want a 9 to 5 schedule, older vets retiring. I just spent $249 for a ten lb container of Throid L, $425 for a 160 day supply of cushing's medication and $106 for Equioxx (arthritis). Add to that 4k to take a horse to a large animal hospital last April only to put him down, another $275. When our last two go, I will miss them but not the work and the bills.
I don't know but cattle operations must be feeling it too?
On a happier note, my area has hit a dry spell, maybe to dry but there is hay making going on everywhere that i go. The farmers are having a "field" day 🙂
Yes small cattle guys are closing up and horse ownership seems to be reserved for only the very wealthy
/ Hay Making on a Different Scale #405
My friend called this afternoon. The baler knotter stopped working, the problem was a plastic gear that drives the knotter. It's covered with thin metal collar, which had a groove worn in it, preventing adequate tension. He discovered he could turn the plastic gear over and it ran in a different spot-Win.
Began baling again and tractor began over-heating and he'd blown out the radiator fins and re-tensioned the belt. He called me because I listen to him vent. I asked if he just removed the 'stat would it harm the tractor, I think I even heard him grin just before he hung up.
/ Hay Making on a Different Scale #406
We solved our weather issue this week. Found Horsenettle (confirmed by Michigan State) in both fields after baling second cutting. Had a local farm service burn out both fields. Will disc this fall and start over next spring. Can stop watching the weather all day for a while. Problem solved...for now.
It will be back. Really, destroy a field because you found some horse nettle.
/ Hay Making on a Different Scale #408
Surely there is a herbicide that would control it isn't there?
/ Hay Making on a Different Scale #409
Yep, Really. After discussing with our County Extension office, and the amount of soybean around us, they recommended a burn down. The fields were old and ready to be redone anyhow, so this was kinda what we needed to just start the process. There are a few things you can apply to try to get it under control, not worth the expense with the conditions the fields were in. Looking forward to a fresh start.
Our customers are predominantly horse people. No need to say more.
/ Hay Making on a Different Scale #410
Horse nettle is a miserable SOB
/ Hay Making on a Different Scale #411
In some States / Counties, you aren't even allowed to eradicate it yourself. The county takes over, burns the field and sends you a bill. Soybeans are the major concern, since horsenettle can be harvested with the soybeans.
It is tough to completely eradicate. Control is more like it. We have some in all our fields. There is no getting away from it. It is a native species so meant to survive. Indians used the seeds for tea/medicine. I haven't tried it yet but is tempting just to do it. Seeds survive in the soil so all your doing is turning up new seeds with tillage. Best control is late fall before it frosts with herbicides so it gets drawn into the roots. Spraying during summer does nothing but reduce the tops. Other than that it is maintain a good stand and choke it out. Lime/fertilize and good stand of grass, however on dry years like we are having here there's nothing you can do. The grass is stunted and horse nettle has a good taproot. Guess which one grows.
/ Hay Making on a Different Scale #413
Toxic to horses and most animals. We have a good local farm service that is used to dealing with this stuff. We will disc this fall after this burn, and then spray again next spring. Discing in the fall helps bring the dormant seeds up, so the spring application has a second chance to catch new growth. Will be tricky, since horsenettle is a late bloomer. Getting seed in the ground as early as possible next spring, hopefully.
This statement is false in my part of the world. Maybe different there but........
Burndown now and disc you might see new growth and spraying again in the fall might be effective.
However, taking you statement "Discing in the fall helps bring the dormant seeds up, so the spring application has a second chance to catch new growth". It doesn't work that way. Anything that might grow now will freeze and be done. Yes the roots are alive in the soil but there is no top foliage next spring. Horsenettle really doesn't show in fields until well into June. Way past the point of putting in a new seeding which for here the cutoff is really early May. Your area I'm sure differs on optimal dates. Even if the horsenettle was visible and you sprayed there would be plant back restrictions unless using Roundup only. There are pre emergent sprays that would reduce horsnettle before it starts growing but have no idea if any of them allows you to reseed immediately.
Not trying to start an argument but something doesn't seem right with what you want to do with regards to Horsenettle control.
As for the toxicity, there are a lot of plants that are toxic. Would take a lot of it to be toxic. On top of that unless you were force feeding it to them they are going to avoid it. Properly timed control spraying, managed mowing intervals, field maintenance, proper cutting heights are always going to be your best methods of control. You will not rid yourself of it. And mother nature will always persevere on your best intentions.
/ Hay Making on a Different Scale #415
Fortunately, we have local Farm Service company doing this for us. They will tell us when to disc and when they are coming back. The tricky part is next spring. Those seeds that will be brought up discing will need to emerge before the second spray. It's just a matter of when we will be ready to get seed in the ground next year after they are done with their program. Don't expect this to be perfect, but they do this for a living, so we are doing what we are told.
The fields were ready for renovation anyhow, this was the last straw. One field was 12 years old, the other 10. The alfalfa was pretty thin, and there was enough other "stuff" in there that this was a good time to renovate. Spending $$ trying to treat would not have made sense in our case.
Always appreciate everyone's input.
/ Hay Making on a Different Scale #416
I always seem to have just enough to have to make a “borderline call” on whether it’s feed hay or mushroom hay.
Annoys the crap out of me, but I’m kind of a perfectionist, so that’s not surprising.
/ Hay Making on a Different Scale #417
Our horse customers "act like" professional perfectionists. Tough crowd.
/ Hay Making on a Different Scale #418
I feel like I see more horses around here that look like they have been forgotten about than I do fancy ones. There is a field a mile or two from my house that I can't remember ever having been cut, it's full of tall trash weeds, junk trees, and a couple of horses just hanging out in it. Been that way as long as I can remember.
Knocked down another field of first. This is our first time doing this field. Received it last fall and brush hogged it. Sprayed most of it this spring for weeds and it got so late we were just going to brush hog it but a friend needs some feed and is taking it. The layout of the field is nice and once we can put some money into it will make a very nice field minus the woodchuck holes. The spray made a big difference, where I ran out there was a lot more crap specifically goldenrod. And since we were talking horsenettle. There was a sea of it in sections. Some of the worst I have seen in a long time. I'm hoping to do a fall spray to knock the weeds back some more. Going to take a few years but this field has potential for hay for sale. In the meantime the plan is baleage.
Irritated I only took one photo.
And doing another run of 2nd. 25 acres down and hopefully get 300 small square bales. Pathetic. Also short on drivers and should be doing all 50 acres but so much raking and tedding with the baling is a lot of ground for wife and I. Keep hoping they take the rain out of Sunday and we would lay the rest down. But I should not be thinking like that either. We are DRY. May and June we could not work and fields were saturated. Over 11 inches of rain. July to today we have only received 2.66 in basically 2 separate rain events. Luckily I fertilized during both of them but still limited growth.
Poor picture taking. Before tedding I raked every 6 windrows toward the center. At least then it looked like I was doing something.
Usually you can watch it fill. Think it took a week to fill. At least shows there is still moisture deep. down.
/ Hay Making on a Different Scale #420
What you call horse nettle we call bull nettle. Same plant, in the same family as potatoes and tomatoes. USDA says eradication is darn near impossible. Best is to control it by frequent mowing. Spraying and manually pulling it are ineffective as it spreads by seed and propagation of roots.
We have a little in the horse paddocks. It grows on bare ground where the horses roll. They leave it alone as it is bitter and they have plenty of hay and grass. Each of the 3 horses has a paddock of 3/4 to 1 acre.
2006 Kenworth W900 Day Cab Truck, VIN # 1XKWDB9X76J112716 (A65563)
2006 Kenworth W900...
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2022 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2022 KENWORTH T680...
