Hay harvesting options for compact tractors.
   / Hay harvesting options for compact tractors. #1
HayDR
Veteran Member, Approved Advertiser
Johnson City, TN
JD 2040,2240, 2355, 2755, 4055
sicklebar mower
single action- conventional mower with fixed guards and a reciprocating sickle knife.
double action- reciprocating movement of the knife inside the guards while the guard knife also is moving in a reciprocating action.
drum mower
single drum mower- knives shear the grass while moving very fast, the mower floats along on a saucer
multi-drum mower- same as above
   / Hay harvesting options for compact tractors. #2
I'm not familiar with a drum mower. You say it cuts with knives, is it like a flail mower?
I presently cut hay with an old sicklebar mower, but would like something easier to use that isn't as expensive as a mower conditioner. How do drum mowers work, and how much are they?
   / Hay harvesting options for compact tractors. #3
Think of a string trimmer. A drum mower works like that, only several lined up side by side, and metal knives instead of plasic line. They aren't cheap, but they cut through dirt & dew, and much faster than a sickle.
--->Paul
   / Hay harvesting options for compact tractors. #5
They'd be fine Rich but they don't have any crimping action. If I was you I'd get a sickle bar type mower conditioner. Used ones can be had for about the price you'll pay for the new drum mower.
   / Hay harvesting options for compact tractors. #6
I had always heard them called "rotary" or "disc" mower. NH calls thier rotary mower conditioner with crimping rolls a Discbine (and thier sicklebar moco a Haybine).
A haybine is ok but a discbine is a much faster and better. Only problem is you need 80 hp to run one; a disc mower, however, only needs 35 or so. The disc type mower can cut a lot faster and deal with tougher and heavier hay .
JT
   / Hay harvesting options for compact tractors. #7
That's what I was thinking, Richard, but I'm always open to any options. I was thinking if the drum mower was easier to use, and cheap enough that maybe I could get a used crimper to pull behind it. So far it looks like a used moco is the way to go. /forums/images/graemlins/smile.gif
   / Hay harvesting options for compact tractors. #8
The rotory mowers are great to cut grass hay for baling - output much like a sickle bar, just no plugging. Can be used on alfalfa, but in most locations a moco/haybine works better for getting good alfalfa up.
Since this thread mentions compact tractors, be careful on moco/haybines - like balers, they need a lot of weight as well as power to run. I put a 9' 1209 JD moco on a 50 hp rowcrop tractor, and I would not have wanted a lighter tractor! They are heavy, & are offset - can be the tail wagging the dog - takes some muscle to make them go around the fields in less than ideal conditions.
--->Paul
   / Hay harvesting options for compact tractors. #9
Thanks, Paul!!!
No, I'm not planning on using a moco with a compact tractor. I'll use my Oliver 1550 (62 hp) for that. I think it'll be heavy enough. It's heavy enough to run my NH baler with a kicker. /forums/images/graemlins/tongue.gif
   / Hay harvesting options for compact tractors. #10
<font color="red"> I presently cut hay with an old sicklebar mower, but would like something easier to use that isn't as expensive as
a mower conditioner</font>
If you want to go with a machine that is way ahead of a sickle bar. They are non clogging and very few moving parts to repair or replace and priced well under $700-$800--You may consider a used NI cut-ditioner--These actually cut much like a frailer and you do get a conditioned hay out the back--your tractor will handle a 7 ft ok.--Pictured below is a example of what they look like.--Ken Sweet
Sweet Farm Equipment Co.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2012 Peterbilt 388 Sleeper Truck Tractor (A53117)
2012 Peterbilt 388...
Kawasaki Mule 4010 UTV (A53117)
Kawasaki Mule 4010...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2001 Chevrolet Silverado 1500HD Crew Cab Pickup Truck (A51692)
2001 Chevrolet...
