Hay Guru's switching gears!
   / Hay Guru's switching gears! #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I have another question about when baling. Reading a farmex moisture reader! In the instructions it says grass hay might show high moisture content. How high is acceptable when baling? I have a 50/50 mix of hay. 50 grasses and 50 alfalfa and clover. What reading am I looking for tobe safe when baling?:confused2:
   / Hay Guru's switching gears! #2
20% or less to be sure the hay won't turn moldy.
   / Hay Guru's switching gears! #3
My moisture meter shows a yellow zone between 17 and 20%, green below that. As I partly recall, there is a magic reading of moisture level for your fingers wrapped around the probe. That is a good way to check the calibration. (25% maybe?? Now I'll have to go look...).
   / Hay Guru's switching gears! #4
I like to see 16 to 18 and less but if it goes over 20 I quit.
   / Hay Guru's switching gears! #5
I didn't trust my meter last year after I read the "higher readings with grass hay" warning in the manual.
Was getting around 25%... those all got a nice dusty, white powder to 'em that would start the horses coughing after a couple of days. Horses liked the hay; so, I fed 'em 1/3 dusty and 2/3 good hay.
I believe the meter now - anything above 20% - stays in the field.
AKfish
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
2003 International 9200I (A53317)
2003 International...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
S/A Utility Trailer (A59231)
S/A Utility...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
