Hay Guru's switching gears!
/ Hay Guru's switching gears! #1
BryanM
Gold Member
Northwest Ohio
John deere 2155, ford 1600
I have another question about when baling. Reading a farmex moisture reader! In the instructions it says grass hay might show high moisture content. How high is acceptable when baling? I have a 50/50 mix of hay. 50 grasses and 50 alfalfa and clover. What reading am I looking for tobe safe when baling?:confused2:
/ Hay Guru's switching gears! #2
20% or less to be sure the hay won't turn moldy.
/ Hay Guru's switching gears! #3
My moisture meter shows a yellow zone between 17 and 20%, green below that. As I partly recall, there is a magic reading of moisture level for your fingers wrapped around the probe. That is a good way to check the calibration. (25% maybe?? Now I'll have to go look...).
/ Hay Guru's switching gears! #4
I like to see 16 to 18 and less but if it goes over 20 I quit.
/ Hay Guru's switching gears! #5
I didn't trust my meter last year after I read the "higher readings with grass hay" warning in the manual.
Was getting around 25%... those all got a nice dusty, white powder to 'em that would start the horses coughing after a couple of days. Horses liked the hay; so, I fed 'em 1/3 dusty and 2/3 good hay.
I believe the meter now - anything above 20% - stays in the field.
AKfish
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
2005 Dodge Caravan Van (A61574)
2005 Dodge Caravan...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
(3) STIHL POLE SAWS (A64276)
(3) STIHL POLE...
