Havoline Synthetic 10-30 "CF"
   / Havoline Synthetic 10-30 "CF" #1
mrutkaus
Platinum Member
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
Havoline Synthetic 10-30 \"CF\"
I got 10 qts of Havoline Synthetic 10-30 on sale at Advance Auto, it is rated "CF" -- do you think this is ok for my Kioti ck30 or should I save it for the cars?
Thanks
Mike
   / Havoline Synthetic 10-30 "CF" #2
Re: Havoline Synthetic 10-30 \"CF\"
What oil and rating does your kioti call for, in your temp range?
Soundguy
   / Havoline Synthetic 10-30 "CF" #3
There are several here that use Mobil One, which is also, a CF rated oil. It is a lightweight diesel oil. I have used it in a compact tractor with good results. If you want a readily available CH-4 heavy-duty diesel oil get Mobil One Truck and SUV. Now having said all of that, I don’t think that there would be anything wrong with using Havoline if it has a CF rating.
I didn’t know that it did. Learn something new everyday.
/forums/images/graemlins/cool.gif
Thanks for the info.
The Kioti manual specifies Shell 10-30 diesel oil, a case of whom I have purchased. Just wondering if I have something better, it being full synthetic, whatever that is these days.
Mike
   / Havoline Synthetic 10-30 "CF" #5
I'm suprised that your manual didn't give you a C* spec with that 10w30 oil.. In any case.. i agree with Jerry.. etc.
Soundguy
2017 FREIGHTLINER TANDEM AXLE DUMP TRUCK (A54607)
2017 FREIGHTLINER...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
