Havn't fired up my DK45 for a month or so ....
   / Havn't fired up my DK45 for a month or so .... #1
warhammer
Central Texas
Kioti DK45SE HST
And when I started it up this weekend it sounded like it clattered more than normal. Not like it was going to blow any minute but louder than I remember it being.
The tractor has 28 hours on it, oil level is good and clean, no smoke. The tractor stays in a barn when not in use.It has a bit less than a half full tank and the diesel was from the last time I used the tractor to mow some acres. I let it idle a bit and after a few minutes all sounded good.
I am wondering if I have a problem here or the oil had just all drained to the pan and it took a couple minutes to recirculate it back up to the topend or .....
Any thoughts?
Warhammer
   / Havn't fired up my DK45 for a month or so .... #2
I think your oil just drained down over the month. The oil filter drains down too and the engine has to run a bit to circulate the oil. If you're up to the full mark on the stick and the noise is gone, I'd say all is well.
   / Havn't fired up my DK45 for a month or so .... #3
I've found with my DK35 that if I cycle the glow plugs a second time in cold weather the rattle at startup is a lot less. If you were starting it in cold weather try that next time.
   / Havn't fired up my DK45 for a month or so .... #4
I wouldn't give it a seconds thought, SOP.
   / Havn't fired up my DK45 for a month or so .... #5
Yeah, the oil had drained down and just needed to be recirculated again. It's normal, so don't worry. Just let the engine idle for a minute or two before taking off.
   / Havn't fired up my DK45 for a month or so .... #6
Shame on you.
Seriously though, mine knocks every time I start it, and even more when it is even remotely cold out. Its stored indoors.
   / Havn't fired up my DK45 for a month or so .... #7
Not sure about the DK, but the factory Kioti filter for my 3054xs has no anti-drain valve, which allows oil to drain back to the sump after a moderate shut down period. I found a NAPA filter, with the valve, and have not had a problem since;the oil light goes out immediatley upon startup and stays out. With the factory filter the light would go off at startup and then come back on for a brief period, indicating a lack of oil pressure: Not Good
8 Piece Excavator Heavy Duty Attachment Set (New/Unused) To Fit CAT 301 (A59225)
8 Piece Excavator...
2011 John Deere Gator Utility Cart (A55973)
2011 John Deere...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2015 DODGE DURANGO RT (A58018)
2015 DODGE DURANGO...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
