Paddy
Veteran Member
Most of us have said, Having the correct tool is important to get the job done. yesterday I had an un-plan break line repair. This means after, I needed to bleed the lines. One of the Bleeders was hopelessly stuck. Neither heat nor hammering would do a thing. I couldn't get vice grips on it either for the space.
The correct tool; Stud remover. This crafty device looks like a socket but has a bunch of nasty teeth on the inside. From the set of 5, you use the first one that won't slide over the stuck stud. With a hammer, pound it on. Then with either a 3/4 wrench or socket, rock it back and forth. I'd say if it breaks, you did all you could. You can use this set for removing smallish nuts as well
Any way, cool tool of the day. If you don't have a set, I recommend them. Saved me the cost of replacing the caliper
