Having a tuff time installing implements on my CK3510
   / Having a tuff time installing implements on my CK3510 #11
One of those fine wire brushes that looks like a toothbrush soaked in drain oil does wonders for keeping female pto clean and slippery. When we were haying I kept one in an old peanut jar 1/2 full of drain oil. Really makes a difference for implements only used once or twice a year.
   / Having a tuff time installing implements on my CK3510 #12
I know you said "drain oil" but I kept reading Drain-O. :whistle: I assume you mean used oil.
   / Having a tuff time installing implements on my CK3510 #13
   / Having a tuff time installing implements on my CK3510 #14
Not sure it helps but, I am running a Kubota with hydrostatic clutch and have found out that I can turn off the tractor engine, and the pto shaft is really easy to turn by hand about a quarter of a turn right or left. Makes a huge difference on lining up the shafts.
   / Having a tuff time installing implements on my CK3510 #15
Yeah used waste oil...hobby farmer's chain lube for haybines and balers. Put it in an old dish soap squeeze bottle, works great for cheap lube. Draino has no lubrication qualitiesšŸ˜„
   / Having a tuff time installing implements on my CK3510 #16
Every time I go to hook up a tiller or mower the splines don't match up. I haven't found a way to shift it into neutral. My other tractor can. I called my dealer twice and they never gave me an answer.
RTFM!
   / Having a tuff time installing implements on my CK3510 #18
Yeah my 3510 SE also has the electric clutch PTO and thus you can't ever rotate it manually. So I do have to give my brush hog a twist back and forth to get aligned sometimes.
Make sure there is grease on both sides.
   / Having a tuff time installing implements on my CK3510 #19
My electric brake is only engaged when the tractor is running and the PTO is off. Every implement I have i can turn the PTO shaft by hand except my 20' FM which has batwing decks and the deck shafts will only turn so far. Therefore when I connect it I have to have the tractor off so that I can turn the spline shaft by hand. All the others I can connect with the tractor running.
   / Having a tuff time installing implements on my CK3510 #20
For my tillers and mowers, I hook them up and lift them up a little, then I can turn the shaft connected to the implement to attach it to the tractor.
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV6NPNJ0431, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2014 FORD F-250 (A58214)
2014 FORD F-250...
2014 Ram 1500 Quad Cab (A56858)
2014 Ram 1500 Quad...
PALLET OF TILE & SUPPLIES (A58374)
PALLET OF TILE &...
