Haven't started my Kubota in over a month
   / Haven't started my Kubota in over a month #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
My tractor is located at my remote property so it doesn't get started much this time of year. Do I need to take any special precautions when starting it after long layovers in cold weather?
   / Haven't started my Kubota in over a month #2
Is your battery on a maintainer? If no power at remote location take battery home with you to keep charged there. Top off fuel before letting it sit to reduce water condensation inside tank.
But starting to use it again... I can't think of anything special to do. Normal maintenance, check fluids, lube, tighten nuts/bolts.
   / Haven't started my Kubota in over a month #3
Check your oil and radiator coolant level , hyd oil level, check air filter for mice:laughing:
   / Haven't started my Kubota in over a month #4
Check all the fluids, drain the fuel filer looking for water. if you have power and the temperatures are below 40F, plug in the block heater for a couple of hours and then start it up.
   / Haven't started my Kubota in over a month #5
+1 on Darrow comments, I don’t use my tractor for snow, so it sits for months.
No problem to date
   / Haven't started my Kubota in over a month #6
Take your battery inside for the night to fully warm it up, and charging it wouldn’t hurt either. The other option would be to jump it from your running vehicle assuming it has a beefy battery if the tractor is cold soaked.
   / Haven't started my Kubota in over a month #7
Here is my thoughts, your getting pretty far south and are probable safe. But for no more than the price I'd put in a fuel supplement. Like I say, your probably safe, but why take a chance. I've been caught twice already gelling up but we've been below zero. Power service and hoses are both pretty go fuel supplements. Other than that I pretty much agree with the other posts.
   / Haven't started my Kubota in over a month #8
Ps. The supplement brands should be power service and howes. I don't know how the "hoses" got there.
   / Haven't started my Kubota in over a month #9
As other said also check to see if any critters made nest or chewing.
   / Haven't started my Kubota in over a month #10
Rodent check first. Quick inspection. Give it a little glow plug and give it a start. Mine sometimes sits for months. Still on original battery (12 years!) with no trickle charge, etc. Cold has not been an issue. Rodents have!! If it starts bump the throttle up a tiny bit and let it run a few minutes then take it for a spin.
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
