Haven't found this crossover pipe available
   / Haven't found this crossover pipe available #1
Lstlk2hi
San Jose, CA
2cats, JD, 2AC, Case 580CK extendahoe, Fordson
This pipe is on boom ram and sends hydraulic power to other boom. It has been welded by a shop in Santa Cruz, CA but the owner did not think it would hold long. He was correct.
Is this available pre-built or do I need to have it made by local welding or hydraulic shop? 1978 Case 580 CK Extendahoe is what the pipe is on.
   / Haven't found this crossover pipe available #2
A piece of hydraulic tubing of the right diameter and length, a T compression fitting and a 90 degree fitting for that short piece, a couple nuts and ferrules for the ends and you're good to go. Around here, that would cost around $40, give or take a little bit.
   / Haven't found this crossover pipe available #3
Here is the type of fitting I'm suggesting. It's called DIN2353 fittings, basically made for tubing. These are metric but I'm sure you have there something similar, I believe you guys call it Swagelock fittings there.
All it needs is the tubing to be cut, deburr the edges, slide it in the fitting, tighten the nut and it's done. Not need to go crazy tight either.
   / Haven't found this crossover pipe available #4
Case uses standard JIC flared fittings and regular steel tube. The tee will be special, if you can’t find the materials locally I have the materials to make it from our stock.
Thank you both for giving me idea(s) on DIY replacement. Working on getting measurements and how to attach w/o causing probs on the boom. Thx again.
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55302)
New Holland 1412...
1837 (A51248)
1837 (A51248)
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
1985 Ford Ltl9000 Tender Truck (A55302)
1985 Ford Ltl9000...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
