Have you used Urea
/ Have you used Urea #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Never seen a post here regarding the use of Urea and just kinda wondered if anyone here is or has used the fertilizer in the past. At 47% nitrogen I would think it to be a great way to get corn to produce well.
I have also heard that Urea needs to actually be worked into the soil, not sure if it breaks down to UV exposure or what.
It is supposed to be a lot less corrosive to machinery that handles it. Further it is not explosive as some other fertilizers can be when they make contact with diesel.
I'm also wondering at this point if Urea can be dissolved in water to be used in a boom sprayer to green up the lawn.
Anyone here have more info on the stuff, are there any down sides to using it?
/ Have you used Urea #2
Yes, I have used both %. they have a 47 and a 60%. It makes the lawn green, very green; but if you put in on in 100 degree weather without water or too heavy it will burn the lawn.
/ Have you used Urea #3
One other very handy use for urea is it makes beer cold, one bucket of water with a couple of pounds of urea add bottles of beer , wait 15 min and they are as cold as.
/ Have you used Urea #4
</font><font color="blue" class="small">( Yes, I have used both %. they have a 47 and a 60%. )</font>
Hey Mike, I don't quite understand how urea could have those two different percentages of nitrogen. Pure urea has about 47% nitrogen and if it was less than pure, the percentage of nitrogen would go down, wouldn't it?
Call me Confused /forums/images/graemlins/crazy.gif
Now I'm starting to understand why some folks like Urea. /forums/images/graemlins/grin.gif
BTW I have never heard of 60% Urea, and I searched the web. I may have missed it but all reference that I saw referred to the 47% nitrogen content.
/ Have you used Urea #6
Mike,
I use urea on my yard every year.
As mentioned, it does make it a very nice green.
Some notes:
It is best to put down right before a rain. To avoid the burning already mentioned but also because once the urea is exposed to the air it'll actually start to evaporate.
Make sure the coverage is pretty even. Since it will make the color a nice dark green (and grow faster), you'll end up with light green stripes in areas if you missed them.
I also know people that use urea as opposed to salt for melting ice in the winter. Works about the same but has no corrosive properties and the runoff is actually good for the lawn.
Brian
/ Have you used Urea #7
Did someone mention beer again? /forums/images/graemlins/tongue.gif
I've used urea for greening up the lawn. You have to be carefull to get lots of water on it or it will burn the lawn. I've also used it to melt ice. It works well under 32, but not so good under 20. It also cooked my lawn along the driveway about 2 inches in, which was fine, because I wanted to edge there anyway.
Read this about applying urea(down near the end).
As for explosives and diesel fuel....
Urea is not an explosive. Neither is ammonium nitrate. They will not detonate by themselves. However, we all know what they can be used for if mixed with other things and detonated on purpose. Either one is a very safe fertilizer when used as a fertilizer. /forums/images/graemlins/wink.gif
Moss if I read that info correctly Urea can be mixed with water and sprayed on the lawn. The rate is 20 pounds per acre. I'm thinking about trying some in a boom type sprayer to see what kinds of results that I'll get, hey who knows it might really make the dandelions grow swell. /forums/images/graemlins/wink.gif
I'm also going to use some Urea to side dress the sweet corn. We'll see how that works out later on.
/ Have you used Urea #9
Mike,
I only skimmed through the article MossRoad posted but if I read it correctly, that measurement is for when you're applying urea when planting.
If you're spreading on an established yard you're probably going to want a lot more than 20#/acre. I don't have an exact quantity/measurement in my head but I'd say I spread closer to 200-250#/acre on my yard but make sure it's going to rain very soon afterwards.
Brian
/ Have you used Urea #10
No clue, just know what the wife got at work (agway for me last year)....Unless I was reading the Uniformity index (UI) on the bag or Molecular weight ? or maybe potash ???
To many "free samples"...everyday it is something. The scotts does work good though!
Latest "at home sample" will be a SkeeterVac Mosquito Exterminator ..OH BOY, coming next week.
The only GOOD part of this is the little giant ladder guy is at the big agaway show and we are getting a good deal on one...
Brian ideally spraying Urea mixed with water would be my choice of distribution methods. Besides it also gives me a reason to build a 3-point boom sprayer. /forums/images/graemlins/grin.gif
I guess that shouldn't change the pounds per acre measurement though.
/ Have you used Urea #12
</font><font color="blue" class="small">( Urea is not an explosive. Neither is ammonium nitrate. They will not detonate by themselves. )</font>
Well, that may be overstating it a little. Anyone remember reading about the Texas City explosions in 1947? Ammonium nitrate sure blew up then! /forums/images/graemlins/shocked.gif
Texas City Ammonium Nitrate
Tom
/ Have you used Urea #13
Mike,
I checked with a friend who uses it on his hay fields and lawn. He uses 100# per acre. He sent me a quote from Ohio State that gave the same 100#.
He said 200# is too much (a waste since 100# would do the same). In either case, rain afterwards is important to stop the potential for burning as well as evaporation.
I have some urea that got exposed to air/moisture and the pellets are now big clumps. I think I'll put these in my boom sprayer.
Brian
/ Have you used Urea #14
</font><font color="blue" class="small">( Never seen a post here regarding the use of Urea and just kinda wondered if anyone here is or has used the fertilizer in the past. At 47% nitrogen I would think it to be a great way to get corn to produce well.
Anyone here have more info on the stuff, are there any down sides to using it? )</font>
I've used it in the past on my corn, but wait till it gets established well (say 12" tall) and water the snot out of it after application or it can burn. I put it in a bucket and lay a line near the base of the row. A 1" wide strip should suffice depending on soil. Maybe a line on each side, but don't get it too close or too heavy. Keep a row or two untreated for comparison and you'll be amazed at how much greener it gets. You can always treat the control rows after the results are in if you want to perk them up.
I had the same idea for the lawn sprayer, but the feed store didn't really have any ideas as to how much or if it would dissolve. Recommended liquid nitrogen, but again unsure of treat rate.
P.S. Keep it dry or it will clump up.
/ Have you used Urea #15
It blew up because of the way they fought the fire on the ship. Instead of putting out a small fire on the ship immediately, which would have damaged the cargo, they chose to try to save the cargo... bad choice. The immonium nitrate didn't blow up by itself. It had lots of help. /forums/images/graemlins/crazy.gif
/ Have you used Urea #16
Ammonium Nitrate in compressed blocks is shown in my dad's Corp of Engineers handbood as an explosive. I remember reading somewhere that the fuel oil is just used to slow down the explosion and make it more efficient at moving material (as opposed to just fracturing it). I'm fairly sure they said that the fuel oil actually makes it harder to detonate, but gives a more efficient explosion. I don't want to try surfing for that kind of thing from work. /forums/images/graemlins/wink.gif
Mike
/ Have you used Urea #17
It has to be detonated with something like a blasting cap or other small explosion. It won't go off by itself.
/ Have you used Urea #18
Hmm, I should have addressed that one to PineRidge. My point, (and I do have one) was that Ammonium Nitrate doesn't become an explosive only after mixing with fuel oil, it is an explosive all by itself. I know I wasn't being very clear. I'm going to blame that on the heat. /forums/images/graemlins/wink.gif
And, yes, I have also read that it is fairly insensitive, so that an explosion is needed to set it off. I'm not sure if anyone really knows what set it off on that ship. I'm just glad I didn't experience that.
Mike
/ Have you used Urea #19
I used to use urea for my avocado's. They love nitrogen. It is a little more expensive than ammonium nitrate but is I have to haul less of it up the hill. I stopped because you have to apply it below (I forget the exact temperature, somewhere around 75-85f) or it (somethings) the nitrogen into the atmosphere instead of into the soil ( http://www.extension.umn.edu/distribution/cropsystems/DC0636.html ). I have been using potassium nitrate the past season to boost my potassium levels a bit since both soil and leaf analysis said I needed it.
Urea is available in two forms, dry which is 46% nitrogen by weight and liquid (un32) which is 32%. I seem to recall them recommending you buy the liquid if you want to fertaligze the stuff or spray it as the dry stuff can be hard to disolve. Then again, I read this stuff a year or two ago so may have forgotten some of it. The only thing generally available with more nitrogen is anhydrous ammonia, a liquefied gas containing 82% nitrogen. That stuff is insideous as pure ammonia suppresses the natural breathing reflex and is odorless. Nasty, NASTY stuff.
I think I remember it is made from seaweed whereas ammonium nitrate is made from natural gas, and with america's love of petrolium products, the natural gas product is of course cheaper.
As for a lawn, I suppose once you dilute it enough to not burn the lawn it will be ok. Just remember do spray it early in the morning so it has a chance to get absorbed before it gets too hot.
/ Have you used Urea #20
Ok, so later this morning I'm taking the plunge ......
Pineridge hooked me up with a local source for urea and I went up yesterday and picked up a couple of 40 lb. bags at a local feed store. The stuff looks kinda like ice melter - little balls - which according to the guy at the feed store are "prills".
I asked the guy about applying it in solution with water - he said that it could be done, but since since the prills have a slightly waxy coating it would have to be put into warm/hot water to get it to dissolve. He didn't have a whole lot of info on this manner of usage other than what the normal (dry) application rate per acre was .... which I have now forgotten. /forums/images/graemlins/grin.gif He did say be sure not to get any on the plant leaves (although he really didn't have any idea how dillute of a solution I was going to be applying ... and neither did I for that matter /forums/images/graemlins/grin.gif)
Tonight I prepared enough premix solution for 150 gallons of urea/water solution. What I did was take some old 2 1/2 gallon fertilizer jugs and fill them about 2/3rds full with hot water and then add 3 cups worth of urea. It was fully dissolved within 10 to 15 minutes. It sounds from some of the links referenced here as though it might make more sense to do this immediately before you are going to apply it, due to the chemical decomposition. I capped all the jugs - hopefully they won't explode /forums/images/graemlins/grin.gif
Each one of the premixes with 3 cups of urea will be mixed with water to fill my 25 gallon sprayer. I was trying to be conservative - and not do something that would end up frying my corn ..... I think 3 cups of urea per 25 gallons of water will probably be a fairly dillute solution. I believe I used slightly less than 1/4 of a 40 lb. bag, which will be used to dress 3 rows of corn.
I intend to use the spraygun/wand to side dress the solution on both sides of each of my rows. I only have 10 or 11 rows and they are only about 60' - 75' long. I'm figuring 25 gallons of solution per side would be a good place to start. Be interesting to see how it works out.
2001 Freightliner MB55 Bus (A61568)
2001 Freightliner...
2017 Kubota SVL 75-2 Skid Steer (A61166)
2017 Kubota SVL...
2020 Ford Transit 350HD Cargo Van (A61568)
2020 Ford Transit...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A61165)
2021 Ford...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61568)
Pallet of...
Grasshopper 322D (A61567)
Grasshopper 322D...
