Have you tried the HF metal cutting Circ Saw?
   / Have you tried the HF metal cutting Circ Saw? #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I picked up the Harbor Freight Metal Cutting Circ Saw #8897 and it does a great job. I hope they come out with a 14 Chop saw style with this blade and RPM. I cut some 1/4" mild steel plate at a rate of 6" in about 40 seconds and even tried some 3/4" and at a rate of 6" in about 120 seconds. I bought the warranty as I am getting ready to start the fab of a grapple and I will put it to an endurance test on that project alone.
   / Have you tried the HF metal cutting Circ Saw? #2
I may sound like the safety police but maybe wear a decent dust mask cutting up all of that metal. Nothing like sneezing out metal flakes later in life.
This saw uses a blade that looks like a carbide tipped blade but is made specifically for metal. Its metal particles are shaved of and are about as long as the plate is thick or a little smaller and they aren't airborne so no dust to worry about but thanks for mentioning it.
   / Have you tried the HF metal cutting Circ Saw? #4
Randall, you are a busy bee. I liked the fel sub soiler, are you making a grapple for your bucket or a whole new attachment?
I am going to try my hand at making a grapple using rippers like the ones used on a box blade. I am starting with a plate like the E-bay model that I showed you in the ripper post. I am having trouble finding suitable material to use for pin bushings. I tend to do a lot more welding in the cooler weather.
   / Have you tried the HF metal cutting Circ Saw? #6
funny you say that you are rippers out of a box blade, i thought of using that on a "bucket grapple" for my bucket. i will watch and see how yours comes out. I don't know where to find pin bushing. looking at the grapples on ebay (the ones for $350) it looks like they just bolt together. i don't guess they will last as long. I thought of using solid 1/2" rod and threading each end, slip that into a 1/2" tube, with the threads sticking out on ether end use a large fender washer and locking nut to hold in place. on the out side of the tube drill and tap for a grease fitting. Don't know if that would work but thats what i was going to try.
good luck and keep me posted
brian
brian
You could try it, I have had many tries and some successes. I have just about decided to use schedule 80 black pipe for pin bushings. I was looking for a place to get hardened ones to last longer.
   / Have you tried the HF metal cutting Circ Saw? #8
That's a good idea, I bought a cheap air compressor from them that I plan to work the **** out of, and, at the end of 3 years I get a new one if it has the slightest problem. I've already taken it back once and they gave me a new one with no trouble.
   / Have you tried the HF metal cutting Circ Saw? #9
I had some pins and bushings made @ a local machine shop for the grapple i am making I think he charged 60ish which would have taken me more than hour to do. I'll get a photo if ya want. fyi grapple would a great reason to buy a plasma cutter. lol have fun welding as i have several hrs in mine already and probbly 8 more to finish it.
   / Have you tried the HF metal cutting Circ Saw? #10
if you don't mind on the photo of the bushing that would be great
thanks
brian
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
WESSEX CHT-100R-E LOT NUMBER 237 (A53084)
WESSEX CHT-100R-E...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
