Have You Operated a Large Auger With Your Tractor?
   / Have You Operated a Large Auger With Your Tractor? #11
I have a 24inch auger for my tractor. I used it to plant trees. Broke a few sheer pins in the process
Tractor is 63 hp at the pto. Id say it depends on your tractor and your soil. My soil is rocky and had a lot of roots.
   / Have You Operated a Large Auger With Your Tractor? #12
i use a ten inch by fifty one foot auger with mine ...
pto drive, no idea how much power it needs ??
   / Have You Operated a Large Auger With Your Tractor? #13
Sign companies have large augers for sign supports. Room on property for large truck?
Pole barn companies also usually have large augers. If there's one near you you might try them.
Aaron Z
   / Have You Operated a Large Auger With Your Tractor? #14
What do you do if you hit the rock with a big augur?
   / Have You Operated a Large Auger With Your Tractor? #16
839EAEAC-2888-4716-9F83-4C973F6FDF87.jpeg this is a rock i found with a 24” auger. It was mounted to skidsteer.
Isnt there any rental yards in your area? I rented a skid steer with 24” auger for $200 for 3 hours use when i set my front porch. Rental yard 20 min away so it wasnt bad. No way my 45 hp kioti would have pushed that auger into the ground
   / Have You Operated a Large Auger With Your Tractor? #17
When we built our cabin in AK - there were 16 holes that had to be dug. They were ALL dug by hand with an old manual clam shovel digger. And believe me - it WAS NOT sand. It took three weekends to dig all the holes. Because of frost they were all dug to 6' deep.
We made our own concrete. Poured the open holes full of concrete. Brought the piers up to grade with 12" sonotubes. It provide a more than adequate foundation. The entire cabin was built in 1976 and stands, rock solid, to this day.
   / Have You Operated a Large Auger With Your Tractor? #18
This is exactly why I got a M62. I can just throw a HYD auger on the front and drill whatever I want. Rental is 45 min away but doable.
His piers could be 6 feet deep. Good luck with that shovel.
How much more in concrete costs will the horizontal piers cost ya? When I looked at this it was quite a bit more than a vertical cylindrical pier.
I'll pass on that idea...
How many piers? Get an 8" augur bit, lay out the 24" hole,
drill 3 holes around the perimeter, and use a shovel to finish it?
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2008 Honda CR-V SUV (A55853)
2008 Honda CR-V...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
