Have you ever tilled a driveway
   / Have you ever tilled a driveway #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
I had a guy I know ask me if I would till his gravel driveway. I have never heard of this. He said it it mixes the fines up with the larger stone. I guess it is like using scarifiers on a grader. BTW I told him no.
Bill
   / Have you ever tilled a driveway #2
I can't imagine tilling my drive way. It is packed so hard, I think the possibiltity of something on the tiller or tractor breaking is higher than I would risk.
   / Have you ever tilled a driveway #3
I could be wrong, but that sounds like a profoundly bad idea.
   / Have you ever tilled a driveway #4
I bought a compact tractor real cheap due to this practice. Rumor had it that some genius used the rental tractor to till his driveway. He kept replacing the shear bolts with stronger and stronger bolts until the PTO shaft busted inside the tranny.
I put over $700 worth of parts and 30 hours of labor into it.
Don't do it.
   / Have you ever tilled a driveway #5
Landscape rake set on aggressive mode does a hard packed driveway wonders.
   / Have you ever tilled a driveway #6
Caterpillar make a 540HP rotary road remixer for road reclaimation.
Sounds like he wants you to be the poor mans version :eek:
   / Have you ever tilled a driveway #7
This is exactly what I use. I Have a rack that holds 4 cinder blocks that is bolted along the top of the rake and adjust the # of blocks according to the amount of "down pressure" I need. It does an amazing job, I haven't used my box blade on the drive since the first time I used the rake. I use this to regularly maintain my drive and crown, smooth, fill ruts and bring some of the larger gravel to the top.
In fact, I cut 4 feet off the width of my entire drive this spring down to the bottom of the drive's bed. The rake set on an angle would cut an inch or so with each pass and windrow the gravel. I incorporated that gravel into the remaining drive and now have a drive with a very defined edge and grass has taken over the part I cut out.
I can tell you, the hard packed gravel would have destroyed my tiller.
I also use the rake to pull out clumps of weed/grass that appear occasionally in the areas that aren't driven on regularly. After a good soaking rain, it will pull them out with the roots very easily.
   / Have you ever tilled a driveway #9
why is it the one who comes up with these ideas is always the one with nothing invested?
   / Have you ever tilled a driveway #10
I'm also in the camp that won't use a tiller. I have used the scarifier teeth on the box blade to break up parts of the surface and have used a disc to break up a dirt roadway so the grade could be reset. Right now my driveway could use either another overspread of stone or renovate the surface and regrade it. Neither will in reality happen before next summer - too many fish to catch in the short term.
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
John Deere 7130 (A50120)
John Deere 7130...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
Toro Zero Turn (A50324)
Toro Zero Turn...
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
