Have you ever had a hard time starting a fire on a pit or a file of wood debris?
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Have you ever had a hard time starting a fire on a pit or a pile of wood debris?
Have you used a diesel for starting to burn the pile of wood debris?
This propane torch will give you an answer on how to start the fire on the pit or wood debris.
The full propane cylinder can start the fire about 4-6 times and is easy to refill .
No more pouring diesel
You should have this torch if you are living in the rural area.
Jkk
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #2
It is how I do it for years
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #3
When starting brush fires I have diesel and oil mixed in a 2gallon hand pump sprayer. Works great and acts like a flame thrower being able to move the fire around.
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #4
Use DIESEL. It will ignite at a casual pace, unlike gasoline that is nearly spontaneous!
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #5
I cut down cardboard boxes into roughly 3' x 3' panels which I place under oil trays, diesel filters, etc., to absorb spills and splatter. When one becomes partially saturated it gets cut into strips for fire starters.
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #6
I burn green wood every year after cleaning up the small branches from trees that fall or are felled. My method is to make a pile, squish it down with the FEL on my YM2310, then apply the weed burner. After the center starts to burn I turn on a small squirrel cage fan and point it into the flames. This works quite well and involves no accelerants. Sometimes the core of the pile burns up and the rest of the pile doesn't catch. When this happens I just use to FEL to compress the pile again. Then the pile burns and I can keep putting on fresh wood. The piles are about 7 feet in diameter.
Eric
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #7
I have two, and I haven't used either of them... I'm something else.
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #8
My Fire starter kit.
Diesel fuel, waste oil, propane torch and a gas or lately a battery blower. Of course there's waste cardboard and other easy to light stuff.
This one was a battle to get started. Last Thanksgiving day, freezing rain that turned into a wet snow. I got it going without burning that little car tire, it's a last resort type thing but always works.
This was towards the end of the day with just that little bit on the left to add in later.
While I'm at it I had 2 more big piles in other parts of my property.
December 1st, this one started well and I fed it all day long keeping it burning like this.
The snow cover makes a big fire worry free!
I used diesel for many years.
But diesel prices went up rapidly which is more than $5 per gallon now.
This propane torch with a cylinder refill is a lot of better option and no diesel waste. 😂😂
Jkk
   / Have you ever had a hard time starting a fire on a pit or a file of wood debris? #10
I burn a lot of yard waste in my fire pit, which is a 7 foot diameter ring of stones. I've taken to laying an old pallet down first, before piling debris into the pit. It offers airflow sufficient to burn just about any green yard waste, thanks to forge/chimney effect created by allowing air space below, and also provides a little dry fuel at the bottom of the pile to help get things started.
I pick up pallets whenever I see someone leaving them out for trash, just for this purpose. No chemical accelerant required.
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
2008 FREIGHTLINER B2 BUS CHASSIS (A51222)
2008 FREIGHTLINER...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
