Have we been doing it wrong? High rpm's bad when not needed?
   / Have we been doing it wrong? High rpm's bad when not needed? #102
I don't even follow what people are talking about anymore. We go from talking about working rpm's, to DPF's, to transaxle's, to limp Kukje's! This thread is out of control!
   / Have we been doing it wrong? High rpm's bad when not needed? #103
government mandates usually mean cost, lack of choice, and the science doesn't really matter when the experiment has a predetermined outcome. When a particular government determines how you make your product, innovation loses out and most consumers carry the fallout via their pocketbook and subsequent lack of choices.....
particulate fallout (almost all of this falls back to earth) is obviously not a greenhouse gas.....a re-gen produces greenhouse gases ..... go figure. Everyone wants clean air and water but the industry gets hijacked by politically motivated mobs of disingenuous bureaucrats and you have problems that most citizens don't deserve.....Rural people somehow always get displaced by the whims of suburbia and metropolitan mandates. There is an education to be had out there....All of us have some degree of ignorance, but reason and common sense usually fill in our shortcomings.
   / Have we been doing it wrong? High rpm's bad when not needed? #104
This graph shows soot production as a function of power and rpm. BMEP which is effectively torque is on the vertical axis and rpm on the horizontal axis. You can see there is a sweet spot of low soot right in the range where its putting out some power at a range of operating rpm. I don't know what engine its for or how much it changes for different engines but at least it's an idea of how it is for one engine.
You can tell that letting it idle with no load is going to generate many times more soot that working it.
Oddly, there is a second sweet spot at 3000 rpm with little or no load.
   / Have we been doing it wrong? High rpm's bad when not needed? #105
Apostrophes make a noun possessive, not plural.
   / Have we been doing it wrong? High rpm's bad when not needed? #106
I don't buy the human GHG causing climate change idea. But soot is harmful to breathe, and it can travel a very long way before it drops to the ground. I am talking about more than 1000 miles. That is why cities get foggy from emissions and smoke from forest fires makes the sky hazy several states away from the fire. But rural diesel emissions are a very small part of that, especially if they are properly tuned.
   / Have we been doing it wrong? High rpm's bad when not needed? #107
I wasn't defending the harms of particulate fallout.....as in which comes first, the "man made Co2 causing forest fires" or a much more complicated natural cycle with the sun at the center?
   / Have we been doing it wrong? High rpm's bad when not needed? #108
I don't want to derail the thread by talking about climate change. But I will add this food for thought. Mars has been seeing global warming of similar magnitude to Earth, when adjusted for distance from the sun. No human GHG there! Seems it must be driven by solar output.
   / Have we been doing it wrong? High rpm's bad when not needed? #109
   / Have we been doing it wrong? High rpm's bad when not needed? #111
But you can't spend trillions and vilify your opponents unless it's "their fault" and you are the "savior" who requires more power to save them.
   / Have we been doing it wrong? High rpm's bad when not needed? #112
But statically, people in cities (who are breathing in lots of diesel particles, from busses and heavy traffic) live longer… go figure
Now there’s all these new studies showing particles from tires and brakes wearing , are more numerous and terrible for you and the environment, along with silicon dust from county back roads.
Follow the $ and the politics
   / Have we been doing it wrong? High rpm's bad when not needed? #113
I did not know that city people lived longer; it was surprising to me. I found the below article link, which suggests that access to health care, a higher % who smoke, and more obese people may be responsible. I certainly do not think urban air pollution helps longevity!
   / Have we been doing it wrong? High rpm's bad when not needed? #114
It would certainly feel like it, I couldn't stand living in a city.
Hell I don't even want to live within a Village limits.
   / Have we been doing it wrong? High rpm's bad when not needed? #115
There has been much published about this. A small sample: NASA Astrobiology
Not sure we're reading the same article.
The one you linked mentions that no doubt Mars has undergone large-scale climate change in the past, that it *may* be undergoing climate change currently (unsurprising that some change occurs, but there's no mention of magnitutde) and it also mentions seasonal climate change.
There's no comparison with what's going on on Earth.
   / Have we been doing it wrong? High rpm's bad when not needed? #116
I suggest continuing your research. I don't have time for it. But here is an interesting graph that puts Earth's climate into perspective. We will eventually go into another ice age. We can adapt to whatever the current climate changes are.
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
