Have run into a health issue - need prayers
   / Have run into a health issue - need prayers #61
Hi Alan,
Again, you're in our prayers and thoughts. I wanted to mention that the waiting, now that your date isn't until next month, is really the worst part, especially if they are able to do the 'scope surgery as Wagtail noted. The scopes are so minimally invasive that people are often walking around the floor later that same day. In my reading about Renal Cell Carcinoma for my prior PA job in interventional radiology, it said that a very very large percentage of the tumors found are termed "indolent", or slow growing, and present a significantly reduced risk of metastasis until they are really huge. My observations over the 7 years I worked there concur with this. We became involved when people only had one kidbey, for any of various reasons, and a tumor was discovered in it, or if they were too ill or frail for the nephrectomy, and then we would either biopsy the tumor and then ablate it, or if it had enough distinguishing characteristics that no biopsy was requested, we'd just ablate it. How?, by freezing it using long needle-like probes that were cooled by argon gas. We used a CT-Scanner to place the probes and watch the freezing process to make sure the whole mass was treated. Just like freezing a wart, except on the inside.
Anyway, keep a positive attitude, and probably most importantly, remember to breathe- take at least a couple full deep breaths every hour while awake as practice and to get ready for the recovery process, and anesthesia. It helped me through the waiting to get my new knee, and made the recovery process easier too.
Take care and God bless,
Thomas
   / Have run into a health issue - need prayers #62
I'll keep you in my prayers. Hope you have a speedy recovery.
   / Have run into a health issue - need prayers #63
Alan, Your operation should already be over. Prayers for your quick recovery.
Thanks for all the prayers. Had successful laparoscopic radical nephrectomy on Tuesday, nearly a week ago. Will get path reoport on my follow up Thursday.
More pain than I expected but I dropped the pain meds Friday due to lack of action in the bowels. That seems to be coming along now. Problem now is one of the three small incisions has quitemqmbit of drainage and we have to keep changing gauze bandages to collect the serous fluid. Haves stained several shirts, underware, etc so kind of a messy deal but getting better at making it where it won't leak over night. Only 2 nights in the hospital, then two nights in my recliner. Have slept two nights in the bed although not comfortably. Walking maybe a half to 3/4 mile each day which unfortunately causes lots of discharge. Have call twice and have been assured not worry unless the wound gets red or the discharge puralent.
Taking some time, not as easy as I thought, but hopefully I can get through this.
Hoping my remaining kidney does the job. Blood numbers day after surgery were slightly out of normal but urologist says that is to be expected this soon. I do know it seems to be making plenty of water that looks normal.
Urologist says everything appears contained, asking for continued prayers for a favorable report and recovery.
   / Have run into a health issue - need prayers #65
Hang in there. Keep positive. Your fellow TBN family members are with you all the way. You are also in our thoughts and prayers. I wish you a speedy and complete recovery.
   / Have run into a health issue - need prayers #66
You got our prayers Alan. Get well soon.
FG19 is planning a TX get together for all the TX members that have or are recovering.
   / Have run into a health issue - need prayers #67
Yep, I just need everyone to get WELL!
   / Have run into a health issue - need prayers #68
Hoping my remaining kidney does the job. I do know it seems to be making plenty of water that looks normal.
Welcome back Alan... I'll take it point by point Mate.
The trouble with the bowel movements is a result of the anesthetic, as I mentioned before this will take months to get out of your system (refer to my 'off with the fairys' comment) but it's normal. A pain in the arse; but normal.
Walking is good, but don't over do it; take lots of 'park bench' breaks whilst doing so. I can't comment to the discharge as it didn't happen with me, but everyone is different, eh?
Keep yourself well hydrated = LOTS of water IOT get your remaining kidney into the swing of things. Keep this routine up for the rest of your life as it will assist your remaining kidney in clearing the extra waste load that the other one handled.
Most of all... DON'T WORRY. If your Urologist isn't concerned (remember, you waited for the 'best' operation) then there is no reason for you to be concerned. DON'T BORROW TROUBLE (as the expression goes).
She'll be right Mate, hang in there.
   / Have run into a health issue - need prayers #69
Glad to see you're improving and back on TBN, Alan. We'll certainly pray the improvements continue and that the report Thursday is good.
   / Have run into a health issue - need prayers #70
Good to hear everything went well and you're recovering.
Eddie
2016 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2016 Nissan...
Flat bed utility truck with inline 6Cy engine (A55315)
Flat bed utility...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
