Have I Ruined my Ford 8n Engine?
   / Have I Ruined my Ford 8n Engine? #1
jackbnimble
san angelo texas
8n
I have been trying to get my 8n working by replacing carb, new distributor, plugs etc. Will start, run for a few minutes then die. Started this morning. It immediately went to max rpm, backed off, began to sputter, ran rough then died. I am wondering if racing engine cold harmed internals of engine etc. I am at my wits end trying to get this tractor to run acceptably well.
   / Have I Ruined my Ford 8n Engine? #2
Sounds like a fuel problem. Unhook the line at the carb and see if you have good fuel flow from the tank to the carb since you replaced the carb. I wouldn't think you hurt the engine this morning.
   / Have I Ruined my Ford 8n Engine? #3
Ford 8N entered the market in 1938, so your tractor is nearly 80 years old.
Have you done a compression check so you have an idea of the general condition of the engine?
I doubt you damaged the engine this morning.
   / Have I Ruined my Ford 8n Engine? #4
Disconnect fuel line then turn fuel on and drain into bucket awhile. Make sure fuel stream remains constant and strong. Sounds like you have a fuel delivery issue to carb.
Also make sure new carb is set to factory specs.
   / Have I Ruined my Ford 8n Engine? #5
Close but not quite.
The 9N first came out in 1939.
The 2N in 1942.
The 8Ns came out in late 1947 but were considered a 48 model.
   / Have I Ruined my Ford 8n Engine? #6
Do you still have fuel glass and filter screen? Check it because slow flow makes all the difference. Sounds like bowl is filling then not keeping up with use.
   / Have I Ruined my Ford 8n Engine? #7
on some old carburetors there is a in line screen under the brass fuel inlet in the carburetor, take out he brass fitting and there may be a small cylindrical screen under it,
   / Have I Ruined my Ford 8n Engine? #8
Crickets:jaded:
   / Have I Ruined my Ford 8n Engine? #9
I agree with the others on this sounding like a fuel / carb issue.
Ignition is at least marginal or better if she is starting up and running briefly.
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2006 BIG TEX 25+5 GOOSENECK TRAILER (A52472)
2006 BIG TEX 25+5...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
