Have I got this figured out?
   / Have I got this figured out? #1
WarrenF
Great State of Idaho
T065 and a 165
Not being a member here for very long....I have enjoyed immensely the discussions and information presented. However, am I correct in assuming that most of the tractors being discussed, do not have adjustable wheels? Meaning if you wanted to plant corn in 36 inch rows, most of the tractors that people talk about on board can not adjust their wheels out to match that type of planting....or conversely if you wanted to plant 24 inch rows....no can do?
That seems to me to limit the uses for the tractor. They basically are an overgrown mower that has a front end loader and the ability to have a small backhoe or blade or rototiller. There is a Kioti dealer about ten miles from me and I will not even look at the tractors for that very reason.
Just thinking and wondering.
   / Have I got this figured out? #2
Well, there's lots of uses for tractors other than row-crop. We haven't row-cropped in years but I still use a tractor nearly every day. We put up hay in the summer, put out hay in the winter, blade the driveway (pretty solid 1/4 mile) push a little dirt around, pull stumps, pile brush, etc.
So, are most of the tractors on this board row-crop?..no. But, my 5005 Mahindra does have adjustable wheels to a point. Not as much as the 720 2-cylinder or the 4320 JD, but then I didn't buy it to row-crop. If I needed a row crop and had different width rows, I would buy one that did adjust. Kind of the train of thought of having specific tools for specific jobs. Ever try to overhaul an engine w/ just a Leatherman tool and a Crescent wrench?
   / Have I got this figured out? #3
What size tractor are you looking for?
Mine goes from 55.25" to 75.25" for the rear wheels. I have a 52 HP (Gross) Long LongTrac, no longer sold in the US due to EPA regs. It is an Indian tractor they now call themselves FarmTrac and sell that older Ford design such as 3510, 6610 etc., with same paint scheme and everything.
Anyway, I am sure there are some models that can adjust the wheels. Big tractors do it with a press of a button, then move slowly. :eek:
My point is why limit yourself to just one type of use...when you can buy a tractor that will do all sorts of tractor things.
   / Have I got this figured out? #5
Like what? What tractor would be perfect for all sorts of tractor things?
You posted this in the Ag Tractors & Machinery board so I am assuming you realize that the guys who post in the forum generally have larger tractors with adjustable tread settings. I can also tell you that I have never needed to adjust any of my tread settings on any of my tractors. I can, but I don't need to.
So I have a question for you. Why pay extra for an option on a compact most people will never need. I am assuming you are referring to compacts with the overgrown mower statement.
Well my thought process is like this. If you wish to plant a garden area, wouldn't it be nice to be able to hook a cultivator bar up and keep the garden clean? If you are farming a bigger plot in addition to all the other uses for a tractor....wouldn't it be nice to adjust your tread to fit the rows and be able to pull a spray rig through the field for weed control?
   / Have I got this figured out? #7
If you plan on doing a good bit of plowing (w/ moldboard plow) track width USUALLY needs to be set to a proper width so the plow can follow centered behind the tractor and still have one wheel in the furrow.
Live in a hilly region? I do. I like to set the track width as wide as is practical during mowing season.
Planting a crop? From a field of corn to a simple big garden plot, row cropping ANY crop where you'll plant or cultivate with a tractor requires some adjustment OR adapting row width to whatever your tractor is set at. (The latter being unacceptable in many cases)
I personally like to have the option of setting track width to what I need rather than compromising to what I'm locked in at.
During the course of a typical summer, it's not uncommon for me to adjust track width on one or more of my tractors several times. (PAVT rear wheels are a gift from heaven!!!)
Your results may vary.
   / Have I got this figured out? #8
So if your uses require these task then you would order a tractor with an adjustable tread. If you are a general landowner who only uses the tractor for property maintainence then you don't need to adjust your tread any more then dishing the rims out or in when you first buy it.
Basically, if you are buying a tractor to farm with then you would order it with adjustable treads. If you are buying a tractor to use for loader work and general maintance then you do not "need" adjustable tread.
Did you try to buy a tractor that didn't have this option? What brought up this topic?
Nope I bought two tractors. I had thought much about a nice shiny new one....then realized that there was no adjustable width. Then, while enjoying this forum, I began to realize the discussions were primarily about tractors in the 25 to 35 horse power rating.....and no one talked about doing any "farming" work.
Now then if you have taken offense at my thinking out loud....sorry about that. It was simply an observation and a conclusion. As I stated on another post in this forum....I am partial to the older tractors....you know those that blow diesel smoke back into your face....and the ones you have to shift....but that is just my preference.
   / Have I got this figured out? #10
I'm kinda glad you DID post this as I learned something about why tractors have adjustable wheel widths now. Since I never used one for planting, I never really thought about row spacing and such.
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
