Have a Kubota b7100 can’t get the 3 point hitch to go down it’s stuck in the up position
   / Have a Kubota b7100 can’t get the 3 point hitch to go down it’s stuck in the up position #1
chrism1088
Kubota b7100
Have a Kubota B7100 can’t get the 3 point hitch to go up or down it’s stuck in the up position
   / Have a Kubota b7100 can’t get the 3 point hitch to go down it’s stuck in the up position #2
That happened to my B7200 not long after I got it. It was a Florida transplant that the "transporter" couldn't get back in shape.
Anyway, the lift jamed UP, just like yours. I could get it restored to operation by jumping on the tool bar. Until it wouldn't budge.
Rusted hydraulic cylinder !
Seat off, Lift off, Looking right in on the bull gears and fluid.. Pissy green color.. Oh Well ;-)
Hammer out the piston (the push bar is free floating.)
Clean up the piston, the seal and the supporting ring. Then hone out the cylinder bore enough to clean up the rust. It was not deeply pitted anywhere. Rinse out the debris with Brake Cleaner, Grease it all good on assembly.
PRESTO works as well as the day it was made.
   / Have a Kubota b7100 can’t get the 3 point hitch to go down it’s stuck in the up position #3
Make sure the flow rate control valve (knob under the seat) is not closed all the way. If it is, the 3-point will not be able to go down -- it will be locked in the up position essentially. Turn the knob to open the valve and then it will go down when the lever is moved.
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
1267 (A50490)
1267 (A50490)
