Have 7-14 R1 4PR. Upgrade to 6PR or fill?
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #1
JohnFourteenSix
Bronze Member
Kissimmee, FL
JD 3032e, Bobcat T180, Mustang 3003
I've gotten two flats on these tires ever since I bought the tractor (about a month or so). They came with regency brand 7-14 R1 fronts which are 4 ply. Should I upgrade to 6 ply tires, or fill them with foam/slime? I'm doing some loader work, and sometime ride around boards with nails, barbed wire, and other goodies. Now I have a slow leak (but not slow enough!).
From what I've researched, if I fill them, it will pretty much mean I need to get new rims if I need to replace the tires.
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #2
6 ply will not stop nails, barbed wire or other goodies. Have them filled if you don't want flats.
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #3
Agree on fill what you have. I buy Berryman's sealer because, even though Slime is available most everywhere there are adverse remarks about it's usage and the Berryman's works for me. I only install what I think will cover the tire, (run tire pressure to max to get it sealed then back to normal) where the leak occurs which isn't all that much. If I fill and test later and still leaking, I add more till it stops and always run the tire a good bit at a good speed to get it dispersed inside the tire. If you don't find it at one farm store, try another.
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #4
You could get tubes for the tires then treat the tubes. That way no solution gets into contact with the rims.
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #5
Since we are on the subject: The 3910 I bought last year had new tread on the tires, but no idea as to when they were installed. One rear had a slow leak. Exploration found a thorn (Locust) embedded in the sidewall half way up. Tire was tube type, 13.6x28 4 ply and air pressure was around 10 psi or a bit over....18 psi rating. I did the plug process with lots of cement and it has held without a problem for over 6 months. So I proved that you can plug a tube. I assume that the tube had been against the tire long enough and in hot enough weather that it stuck to the tire enough to accept the seal.
I put 32 ounces of blue-label slime inside of it. It might not be the best, but it looks like a new tire and front wheel are (relatively) inexpensive. Thank you for preventing me from buying more tires and going through the process of dismounting/mounting. The slime seems to be holding up so far!
   / Have 7-14 R1 4PR. Upgrade to 6PR or fill? #7
Good Luck.
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Electric Mobility Scooter (A51694)
Electric Mobility...
11 10 FOOT BY 5 FOOT LIVESTOCK PANELS (A53843)
11 10 FOOT BY 5...
