Hauling a tractor
   / Hauling a tractor #1
Thomasskala
Blooming Prairie, Mn
Ford
I have a 14000lb trailer that is a bumper connect. I am asked if I would haul a 10000lb tractor 350 miles. It will be hooked to a 2001 Ford F350. Will may trailer handle it?
   / Hauling a tractor #3
If your trailer weighs less than 2k lbs, yes.
   / Hauling a tractor
Can't say for sure, but it is a heavy built trailer and each axle is rated at 7000lbs x two.
   / Hauling a tractor #5
It'll haul it just fine. Even better if you tow it with the 1 ton because it can tote a lot of tongue weight. Make sure your trailer tires are aired up to the max pressure si they dont get hot.
Just curious but what kind of tractor? I ask because my 10000lb 966 IH wouldnt fit on a bumper pull trailer.
   / Hauling a tractor #6
I hope so (and think it will) because I have about the same situation. I have a 14K bumper pull trailer and a Dodge ram the 5.9L Cummins diesel engine rated to tow 12.5K. With a 9500 lb tractor and the trailer it is right about at its rated limit. I will need to haul it 700 miles twice a year for several years, with some mountain grades. I'm betting the Cummins can do it - will find out several months from now. Mine is a SRW, but this and the bumper pull help to hold down the weight a bit.
   / Hauling a tractor
The Tractor I am asked to haul is A John Deere 4040 and right now it is being check out to see how wide it is. I hauled a Oliver 1850 on it two years ago, 8 miles and it fit just fine. I was told the John Deere weight was 9600lbs and I rounded it off to 10000lbs.
   / Hauling a tractor #10
Welcome aboard, this is the place to get your answers. Does this trailer have brakes and does your truck have a brake controller. All states; not having brakes for that large a load on the highway, is illegal. It could void your insurance on that basis. Think liability if Murphy's law prevails.
Ron
2015 Ford F-750 Liftmoore 2550 5,000LB 2.5 Ton Crane Mechanics Truck (A51692)
2015 Ford F-750...
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2017 International DuraStar 4300 Truck (A51692)
2017 International...
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
