Has anyone used peanut oil in their diesel fuel?
   / Has anyone used peanut oil in their diesel fuel? #1
Terry Gable
Florida
2003 Farm Pro 2425
I have about 10 gallons of used peanut oil (turkey frying) and was wondering if anyone has used it in their fuel? If so, did it work well or should I not bother trying? Thanks!
   / Has anyone used peanut oil in their diesel fuel? #2
Filter it well. blend with diesel 50/50 and do not use in cool weather.
   / Has anyone used peanut oil in their diesel fuel? #3
Yeah, the filtering is the most critical part. And I sure wouldn't run it thru anything that has high rail pressures and expensive injectors. On older diesels, it would be a non issue. The newer ones..... you might run into a lot of fuel filter clogging issues. Many fuel filters on the newer diesels are clear down to between 2 and 7 microns of filtering. Those injectors just can't take a stray particle getting in there and messing things up. But if you have a diesel that is using older injector technology, it might be a good way to use the oil up. Or you could give it to someone in your area that is home brewing biodiesel. They have the filtering to do the job right and also will get the glycerin out. You could buy the finished bio back at a fraction of what bio costs at the pump. Mix it in a 10-20% ratio to regular diesel and have a good time.
   / Has anyone used peanut oil in their diesel fuel? #4
But why? Your machine is with thousands of dollars and you're going to poor something foreign in it? I do know people that do but don't understand what the benefit is.
   / Has anyone used peanut oil in their diesel fuel? #5
I would not take the chance! My luck ain't that good. It would blow something up for me!
   / Has anyone used peanut oil in their diesel fuel? #6
By the thread title, I though you meant unused. I had to do that once when my wife brought the 6.5 TD truck home empty so I pulled a gallon out of the pantry to get to the fuel station.
I can't justify saving 40 buck on fuel with the risk of trashing the fuel system. If you must see it used as fuel, find someone that's invested in a full blown system that'll pay you for it. Better yet:
You'd be way better mixing it filtered at 1 cup dish washing soap per gallon in a sealed concentrate 2/3 a cup of the concentrate shaken into a gallon makes a nice bug killer when sprayed on at temperatures below 85F.
Utility Trailer (A52377)
Utility Trailer...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
