Has anyone tried the oil bath Prolube Kit?
   / Has anyone tried the oil bath Prolube Kit? #1
tmronnie
I bought a 14 k trailer with brakes on both axles and I would like to change to oil bath axles seals. This looks like a good way and cheap ? Does anyone have any experience with it or some thing better or is there some thing wrong with it or this type of system? thanks
   / Has anyone tried the oil bath Prolube Kit? #2
Can you do that? On a traditional Dexter type axle? I thought they were completely different set-ups.
Instead of going with a cheaper "no-name" brand, I just ordered a 20' (18+2) Anderson low-boy gooseneck. About $700 more than the no name at $4,100 Out the door (Includes TTT). I didn't even price out oil bath axles figuring that would be too much $$$.
   / Has anyone tried the oil bath Prolube Kit? #3
Yes, you can convert standard Dexter Style axles to oil bat for about $50 per axle. I have gotten them off EBAY and other sites. The kit includes everything you need including seals and the oil. Runs much better/cooler.
Chris
Thanks chris, they looked like the way to go for under $100; I can have 2 oil bath axles and not have to worry with grease, and if I have a leaking seal I should be able to see that the lube is low from just looking. The trailer I got was used ,it is 2001 Anderson 20' gooseneck with deck over, I only use a trailer 8 to 10 times a year.
   / Has anyone tried the oil bath Prolube Kit? #5
You might want to call your dealer and check on the price if not too late. I ordered some Dexter axles a year or so back and was surprised how little it cost to upgrade to various options when ordering. For example I found the EZlube zerks to grease the axle bearings only added about $5 to each axle! Looking at some online sources I wouldn't be surprised if the oil bath option only added $30 or so per axle...
   / Has anyone tried the oil bath Prolube Kit? #6
Commercial trucks use oil bath ft. hubs on trucks for longevity.
It's no different on a trailer.
   / Has anyone tried the oil bath Prolube Kit? #7
I was just reading about these axles and they are NOT recommended for a trailer that sits much, the oil will run down.
here is a picture of the caps
Jim
   / Has anyone tried the oil bath Prolube Kit? #8
Too late. Picked the trailer up yesterday. But it does have EZ Lube 6K Dexter axles. I'm sure it will be fine. It's a little more trailer than I needed, but I have a habit of buying too small. The Anderson quality is evident in the finish work, compared to the local no-name trailer I was going to buy. The no name was rated 14K, while this Anderson is rated 12K...The Anderson is built with SUBSTANTIALLY more steel and a larger main frame. Go figure.
   / Has anyone tried the oil bath Prolube Kit? #9
We will need pics.
Chris
   / Has anyone tried the oil bath Prolube Kit? #10
On duty this weekend. Will get pics on Monday.
2,500lb Traveller ATV Winch (A51573)
2,500lb Traveller...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
