Has anyone made a chain/drag type harrow?
/ Has anyone made a chain/drag type harrow? #1
nyone
Elite Member
Ford 851
Im looking to make one if these type of ground tilling/ smoothing attachments for my ATV. It will be for light road smoothing and making food plots at a hunting lease. The land was logged about 8 yrs ago. The trails are old skidder roads, some un touched for 8 yrs. It will be left there, about 4 hrs away and i only get there about 3x a year.
I have a large pile of scrap steel and more than a few hours under my belt with a welder.
How does say 1/2in rebar hold up to getting drug across rocks and sand?
/ Has anyone made a chain/drag type harrow? #2
1/2" rebar and rocks = bent 1/2" rebar. Sand won't be a problem on it, it will take a while for it to wear out.
/ Has anyone made a chain/drag type harrow? #3
Well - I do not weld - so my "drag" is made of wood. It works just great - breaks up clods, smooths out tilled land, easy to pull - and, most importantly - raises a whole lot of dust. Notice - a set of large spikes across the front and same in the rear. I tow this abortion with a rope bridle attached to my ATV.
/ Has anyone made a chain/drag type harrow? #4
Welding rebar will make the rebar brittle which equals lots of breaking as you drag.
/ Has anyone made a chain/drag type harrow? #5
I don't need or use one but would a section of chain link fence work?
Im really looking for something to rip out weeds, and take off the high spots. If i could till it i would but i cant. So im prety much left with something i can tow behind an ATV without a motor.
/ Has anyone made a chain/drag type harrow? #7
I have about a 9 foot long section of 6 foot wide chain link fence, I have it folded over in half with a "T" post at fold and a length of chain attached about a foot in from ends of "T" post which forms a "V" and makes a loop at point of vee to hook on center shackel of draw bar.... If I need more weight I go over to the rock pile and put 4-5-6 fair sized rocks on it and drag away.... Also have about a 5 foot section of RR track with a couple of holed blown in each end to put chains through, and drag it when I need to knock gopher mounds or whatever down (also can be used on "chain link fence" harrow for weight)....
Dale
I have hurd that the chainlink ones get clogged up with grass/weeds and its almost impossible to clean out? Im working with 3/4ft weeds here. Of corse i will cut the big stuff down and most likely weed wack it. I dont have time to spray and burn. Im only there a week in the spring, a week in the fall and for hunting season.
Mabe i should just scrap this idea and hunt whats alreaty there.
/ Has anyone made a chain/drag type harrow? #9
About 4 or 5 sections of old railroad ties connected together by log chain will also work as a "bump leveler". You can add weight on top of the ties if necessary.
/ Has anyone made a chain/drag type harrow? #10
IF you are doing tall weeds I would think something like linked bars (angle iron/channel iron/pipe) would be better than chain or linked fencing harrow to knockdown tall stuff....
Dale
/ Has anyone made a chain/drag type harrow? #11
i have a section of heavy duty welded wire fencing with a wood pallet on top and about 6 18 x 18 concrete pavers for weight. i drag a spring rake with my "harrow" behind it. have to clean out the spring rake often but it does a great job of breaking up the clumps and leveling. I have about 10 bucks in all of it from a used materials place. had the chain and pavers on hand. you can put some big spike nails in the pallet for a little more action, but i find the spring rake works well.
/ Has anyone made a chain/drag type harrow? #12
My drag works incredibly well. I just used it to smooth 20 acres of disked plots. Unfortunately, have no picture. But started with three pieces of 4 x 6 angle 1/4”. Drilled holes in each end and in the center and bolted 1/2 eye bolts. Laid the three pieces down parallel with about 3 feet or 4 feet between them. Connected them with chains down each side and a middle chain. I also “wove” criss-crossed chain in an X pattern between the three angles. Then attached a chain harness with clevis in the middle to attach to the tow bar or trailer hitch. I’ve drug this many miles. It is bomb proof. It levels and moves some dirt. Sometimes limbs get tangled in and it has to be quickly cleaned. It can be flipped over, runs either way, but digs in more with the angles facing down. I pull it with my tractor or truck. It may be a little too heavy for a ATV, but shortening the angle iron would allow that. It was pretty cheap to build. I’ll try to get a picture soon.
/ Has anyone made a chain/drag type harrow? #13
We use old semi tires (as big as we can handle) with a cast eye-bolt through the tread for a hitch and 5/8 x 4 grade 8 all thread bolts through side wall to prep for sowing grass where we thin timber and flip it over to cover the seed . Works great and dirt cheap
/ Has anyone made a chain/drag type harrow? #14
Unless you have a huge metal scrap pile I would think you could buy one cheaper. I just picked up a new 6' drag harrow for $249.
