has anyone ever heard such nonsense?
   / has anyone ever heard such nonsense? #61
Not that it matters I guess, but it wasn't the OP.
   / has anyone ever heard such nonsense? #63
Just looked in my Husky's manual to see that it has the TuffTorq K46CR: mower is more of a commercial grade one (didn't buy from a big box store) in that it's got a Kawasaki engine and a welded deck (I was wanting this plus a locking diff). This is a locking diff transmission and appears to be fairly different than the standard K46. I am unable to find any mention of problems/failures with this model of transmission: might be because they're a lot more limited production?
Sorry but all k46 trans are factory sealed "maintenance free" homeowner units.
Just nothing commercial about them, dont let CR on the end fool you. Letters only correspond to the controls/linkage locations such as left/right foot/hand & nothing more!
All commercial trans are easy fill/drain units with many of those now being actual homeowner units with reservoir(s) designed to fool buyers.
But no commercials are sealed units.
The hydros made before 2000 or so lasted twice as long due to better materials this country once used. Those days are long gone sadly!
   / has anyone ever heard such nonsense? #64
OK.
Fortunately I've had no issues. I think I've had my mower for about 10(?) years now.
There's "materials" and then there's "engineering" and "manufacturing processes." Good materials alone doesn't mean something is good.;)
   / has anyone ever heard such nonsense? #65
People can say anything, don't believe everything.
I think the dealer guy is misinformed
   / has anyone ever heard such nonsense? #66
Hmmm... when I recently bought my JD Z355E it did not come with a 'towing package', it was an additional option that came as a kit. I'm sure that there is a 'sticker' (isn't there always) stating the towing capacity. There certainly wasn't a separate Towing Package Owner Manual. :rolleyes:
Nothing in the Z355E Owner Manual as the towing package isn't a standard fitting.
   / has anyone ever heard such nonsense? #67
With that logic if you had a 200 pound person they couldn’t haul a gallon of water if you account for there weight the trailer weight and the load
   / has anyone ever heard such nonsense? #68
Just for a newer perspective on hydrostats. Currently working on a Scag Turf Tiger with the liquid cooled engine with separate hydrogear pump and parker wheel motors with drive issues with the right side after about 5 minutes. Had to get the hydrogear flow test kit to determine if it was a pump problem or wheel motor problem.
The test involved setting the pressure valve on the tester at 300 psi and getting a gpm reading, and then increasing the pressure to 1100 psi and making sure that the flow doesn't drop more than 1.5 gallon. Now here is the fun part. While doing that test at 1100 psi the metal parts of the flow meter will get hot enough that you can't hold it in your hands. That temp increase takes about 30 seconds. Now how long would it take to overheat the oil in a hydrostat on a consumer mower pulling even a moderate load in a trailer or going up and down steep slopes on a yard.
   / has anyone ever heard such nonsense? #69
I wouldn’t expect a lawn tractor to do much and would expect more out of something branded as a “garden” tractor
At least back in the day…
(My 12hp garden tractor had(to name a few) buzz saw, grain auger, fork lift, sickle bar, loader, post hole digger and even trenching attachment options lol)
   / has anyone ever heard such nonsense? #70
The early 70's cub cadets had a rear 3 point option and a optional gear driven 540 1-3/8 pto, that happened to turn the opposite direction of all other tractor pto's.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
1991 International 4900 Box Truck (A55315)
1991 International...
LIMA MAC 60KW GENERATOR (A58216)
LIMA MAC 60KW...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
