Loader Has anyone ever had issues with the BX load not going into float?
   / Has anyone ever had issues with the BX load not going into float? #1
Tollster
Benton, Pennsylvania
Kubota, BX23
Curious because I purchased mine used with 50 hours and could never get the loader to float. Today I tore into the 4 position valve and found the issue, it was outside the pressure boundary inside the sealed cap on the bottom of the valve assembly.
Corrosion had fused the return spring collar to the shaft. I can only assume it was condensation from the hot fluid that allowed corrosion to build up, one side was worse with no signs of grease from the factory, and it required heat to break loose.
Fortunately I did not need to replace anything, but it was time consuming since it was investigative, and trying to reconcile how everything inter acted within the controller., furthermore, the collar fused to the shaft stub end flush with a shoulder, appearing as if it was and internal part of the stub end..
Just one of those oddities I thought I would bounce off y'all if it helps anyone.
Mine is a BX 23 TLB..
Tol
   / Has anyone ever had issues with the BX load not going into float? #2
Has happened before. On my loader, lubed everything up and drilled hole in low side of spool cap.
David
We were talking about drilling a weeper yesterday. It was diffinately not what we had expected to find for sure.
   / Has anyone ever had issues with the BX load not going into float? #4
Lots of common issues in that ballpark, all with a root cause of junk building up or sticking in that cap. Affects most makes & models, not just Kubota.
   / Has anyone ever had issues with the BX load not going into float? #5
David
You did that too?? I thought I was the only one.
Anyway, that drilled hole is a good place to stick the spray tube from a can of WD-40 and hose it down.
   / Has anyone ever had issues with the BX load not going into float? #6
Yes do that too, sometimes hosing something down with WD-40 is good. You know that control snaps in like new and no problems. Log splitter did it too once.
David
Good idea, weeper, and nozzle attachment
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
1998 FORD F SERIES DUMP TRUCK (A57192)
1998 FORD F SERIES...
Wooden Rocking Chair (A55853)
Wooden Rocking...
(12) SHEETS OF 3/4" OSB WOOD (A57192)
(12) SHEETS OF...
2017 John Deere 35G (A55973)
2017 John Deere...
