Has anyone came up with a cure for
   / Has anyone came up with a cure for #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
the throttle on the 4000 series working loose. My 4700 in 200 hours has came loose 3 times. I was thinking of trying a low grade Loc Tite on it. It is getting to be a pain taking the dash apart all the time to tighten the throttle linkage. I know this was a problem with most all of the 4000 series so I hope someone has found a cure for it.
   / Has anyone came up with a cure for #2
Loctite 242 (blue) will probably help some...but will not cure the problem. Have you ever installed new friction washers?
   / Has anyone came up with a cure for #3
I replaced the nut on the through bolt at the throttle lever in the upper dash, got a nylock nut at the hardware store.
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
2012 Ford Transit Connect Van, (A55788)
2012 Ford Transit...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
