Has anyone came up with a cure for
   / Has anyone came up with a cure for #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
the throttle on the 4000 series working loose. My 4700 in 200 hours has came loose 3 times. I was thinking of trying a low grade Loc Tite on it. It is getting to be a pain taking the dash apart all the time to tighten the throttle linkage. I know this was a problem with most all of the 4000 series so I hope someone has found a cure for it.
   / Has anyone came up with a cure for #2
Loctite 242 (blue) will probably help some...but will not cure the problem. Have you ever installed new friction washers?
   / Has anyone came up with a cure for #3
I replaced the nut on the through bolt at the throttle lever in the upper dash, got a nylock nut at the hardware store.
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
UNUSED 72" HYD ROCK GRAPPLE (A54757)
UNUSED 72" HYD...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A55788)
2019 Ford F-150...
