Has anybody replaced their hood??
   / Has anybody replaced their hood?? #1
Boiler74
Indiana (Purdue country)
John Deere 4710
Well, long story short, I think I need to replace the hood on my 4710. The hood has been hard to close for some time - really needing to put some effort into it. Finally put some grease on the mechanism to make it work easier. BUT, I noticed that I have cracked the hood where the hood meets the closing mechanism. My fault, even though it's a pretty shoddy design. I've still got a lot of work to do with it, and probably wouldn't buy a new one for a while, except that the TEN series is on it's way out. So, I think I should buy one and put it in the basement for now. Has anybody had to do this, and how much is it going to hurt??
J.
   / Has anybody replaced their hood?? #2
I can't answer your question, but I was wondering if you felt it was beyond fixing? Perhaps if you posted a picture of the crack, you might get some response that would explain how to fix it. Would JB-Weld or epoxy, sanded and painted, repair it? I'm not against buying new, but I hate to see stuff go into the landfill.
Cliff
   / Has anybody replaced their hood?? #3
I had to replace the hood on my 4400. When I first called the parts manager at my dealer, he quoted me a price for the hood. That was in the $200 range. Then he called me back and said that there was a "kit" that included all of the seals, decals, and the hood for just above $200. I looked up the cost on jdparts.com and the cost for the hood alone for a 4710 was $230. Maybe your dealer will know where to find the kit with all of the decals, foam, hood, etc.
   / Has anybody replaced their hood?? #4
I would not buy a new hood so soon. JD will be able to order you a new hood for quite some time after the models are gone. I still order stuff from the 70 series to put on my 990. And I have had no problem getting stuff for the '76 214 or '83 318.
Thanks for the tips. I don't think I would be up for repairing it. In the process of building a house, so most all of my time is elsewhere. But it's good to know parts are still available after the series ends, and the 2-300 hundred range is about what I figured. I'll give them a call when I can. Thanks,
Josh
   / Has anybody replaced their hood?? #6
I had the same problem on my 4600, JD priced out a new hood to be $325.00. I decided to fix it myself by taking the hood off the tractor, purchasing a piece of tin and then cutting it and molding it to fit over the plastic bracket, when everything fit well I epoxied the tin and then screwed it to the existing bracket. So far it has held for 2-3 months, the cost to fix was under $10.00 and about an hours worth of time.
Greg
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2013 John Deere Gator 825E (A51573)
2013 John Deere...
2015 KENWORTH T880 MID-ROOF SLEEPER (A52472)
2015 KENWORTH T880...
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
