Harrows: 3 pt. vs. drag?
/ Harrows: 3 pt. vs. drag? #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
My father-in-law swears by the drag harrows and from what I've seen of my friend's 3-pt ones, the drags do a better job...
What do you all think is better and/or use?
/ Harrows: 3 pt. vs. drag? #3
I have a three point disc that I just love. It has done every job I have asked it to fine and when I am done...just lift and go. It has been perfect for my situation. I have a mile of paved road and once off road, I make a lot of tight turns on logging trails on my way to the field that I work on. It is only a 5 foot disc but I do not mind the seat time! /forums/images/graemlins/wink.gif
Dan
Yes, I am talking about a disc harrow; sorry for the confusion and thanks for the link.
/ Harrows: 3 pt. vs. drag? #5
I just looke dat an older 6' 3pt disc harrow this afternoon. Neat setup. the disc is actually on a seperate subframe than the 3pt lift frame. It has about 6" of travel due to slotted connectors front to back, and side to side. Guy only wants 300$ for it.. I'm thinking of buying it.. looks like it will follow ground terain much better than a fixed 3pt.. but is still liftable like the 3pt.. kinda like a drag/3pt mixed together.
Soundguy
/ Harrows: 3 pt. vs. drag? #6
I have used both. If you want to level land, the drag is the only way to go. I have always had trouble keeping both gangs in the ground with a 3pt disc-harrow. It just seems the drag is more versatile. You can level with it, adjust it out a bit and drag a ditch. It is a little more to manuever around, but I think its worth the trade off.
/ Harrows: 3 pt. vs. drag? #7
</font><font color="blue" class="small">( I just looke dat an older 6' 3pt disc harrow this afternoon. Neat setup. the disc is actually on a seperate subframe than the 3pt lift frame. It has about 6" of travel due to slotted connectors front to back, and side to side. Guy only wants 300$ for it.. I'm thinking of buying it.. looks like it will follow ground terain much better than a fixed 3pt.. but is still liftable like the 3pt.. kinda like a drag/3pt mixed together.
Soundguy )</font>
I don't recall the model #, but Ford made a 3-point disc that had a pivoting hitch that would allow the gang frame to "float" independent from the tractor. They weren't overly popular, but worked quite well, all facts considered.
/ Harrows: 3 pt. vs. drag? #8
I looked all over for a tag.. but could find none.. but then I was in a hurry coming back from lunch. If it was a ford.. I'd deffinately buy it. I already have a way old ford dual ganged dis tha tis worse for wear. Would go great with my ford tractors.
I may have to stop back buy nd look at it again.
It soulds similar to what you describe.
Soundguy
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
43018CFL (A59228)
43018CFL (A59228)
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
1996 RWAY BELLY DUMP (A63569)
1996 RWAY BELLY...
Komatsu PC360 (A64047)
2014 REITNOUER ALUMINUM FLATBED TRAILER (A59910)
2014 REITNOUER...
