Rake Harley Rake questions
   / Harley Rake questions #11
No- I don't know. I found this out thru my dealer. Funny thing happened, same dealer different salesman said their distributor in Michigan couldn't get one, the younger salesman said they had Harley's in Columbus and could deliver in within a day or so. I mention this as FYI to you if your dealer gives you the run around. Franklin Tractor in Columbus has 3- 6' Woods Power Rakes on their lot ready to go. I ordered a "new" one because they are supposedly changing the design somehow. I think the design change is how the flap is adjusted square tube with a pin vs. U Bolts with a nut. See Woods Power Rake website.
Good Luck.
Slippy- What part of the great Buckeye State are you in?
   / Harley Rake questions #12
I think the design change in the flap adjustment from U Bolts with a nut to square tube with a pin was done 2 or 3 years ago. My Harley rake has the new aldjustment and I purchased it in dec. 2005. It replaced my 1997 Woods.
Thanks. I will try to check them out.
   / Harley Rake questions #14
Slippy said:
Anyone have a Harley Rake? Read some of the old posts on folks looking to clear land. Harley Rake looks like it does pretty good job. Also read that ATI makes a similar type model.
Looking to use it on my pasture fields to smooth out some rough places and have some undesirable grass growing in places that I would like to pulverize and reseed. Have other areas were there is just dirt and rock that I would like to clear the rocks out of.
Thoughts, ideas, suggestions?
Slippy, if you are still shopping...I'd check out a TR-3
The Absolute Innovations line of Arena Drags: Featuring the TR3™ Rake!
Yeap. I called them and just got their video. Not sure how it would work on thick sod. Did you use one?
   / Harley Rake questions #16
Yeah I own one...one of the slick things that I use it for is surface stripping when revitalizing old hayfields...
I responded to your other thread...and that is probably where this discussion should continue...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
12' CONTAINER (A52706)
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A56138)
2019 PETERBILT 579...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
