Hardie Siding stored outside uncovered - Still good?
   / Hardie Siding stored outside uncovered - Still good? #11
Bleach my ashcan. Bleach fer laundry.
You got mold you use soda, either baking or laundry. Murder green crud and leaves salt behind dat kills possible regrowth. Why you think insurance company loves sodablasting house dat got wet from firehoses?
   / Hardie Siding stored outside uncovered - Still good? #12
Bleach kills mold everywhere!
   / Hardie Siding stored outside uncovered - Still good? #13
Only temporary. Mold usually well established colony by time bleach arrives. Bleach only kill what it reaches before evaporating.
Like I said, soda kills as well or better, then leaves behind salt dat kills emerging molds.
   / Hardie Siding stored outside uncovered - Still good? #14
should be just fine. i would do it. let it dry out before painting. make sure you are installing with an air gap behind it. usually 1x2 or 4 every 16 on the wall over whatever your weather barrier is, like tyvec and fasten to those to get you a 3/4 air gap behind the siding. look up the install guide.
My prepainted Hardi plank is on the way. I have installed siding as a grunt helper many times and never used firring strips to provide airspace. I'm sure there are utubes etc, I just couldn't find them.
The Hardi Co. web site says hardi plank can be installed directly to 7/16 osb, which is exactly what i got. I also have 6 ft soffits so it's never going to get wet.....probably.
I'm not saying you are wrong, more than 1 way to skin a cat but........If the planks stand off a little, I think I would have problems with the dimensions on the exterior window edge reveal and the brick mold on the doors.....those are all designed for planks to be attached directly to osb.
Funny, I have a bunch of roofing left over, standing seam, very expensive. I've got it on skids but it's 35 each, 25 ft pieces! Now I gotta build another building just to use it up!
My buddy said, man, you gotta get this outta the constant rain. I reminded him it was roofing.
   / Hardie Siding stored outside uncovered - Still good? #15
In my area many roofs with shingles have streaks running down from peak to gutter. I learned it's from bacteria or some other living critter? I don't like it and I'm told it damages your roofing?
I went to a swimming pool co and bought what they call shock? I think it's basically a bleach solution? It worked but took a few applications and in the end, not perfect but much better.
I wonder if baking soda would work better?
Rhetorical question for me really, I now have a metal roof.
   / Hardie Siding stored outside uncovered - Still good? #16
Depends on your roofing material, but garden lime works on red cedar roofing ,.... which I have.
Yeah, I hear you about the furring strips. All the Hardie I have installed it was directly to osb and this has a $500,000 on the edge of a mountain that gets lots of driving rain. Maybe I will just forgo the furring strips, sounds way more of a pain.
Thanks for all the comments, sounds like I should call my neighbor and buy that hardie.
   / Hardie Siding stored outside uncovered - Still good? #18
I build my shop 13 years ago with Hardie siding installed directly over the house wrap to OSB.
No problems to date. Did the same when we built our cabin last year.
   / Hardie Siding stored outside uncovered - Still good? #19
I have a question about a use for Hardie / cement siding boards.
Would it work to use as sides for a raised beds for a garden?
   / Hardie Siding stored outside uncovered - Still good? #20
Maybe but you’d have to stake it a lot. It didn’t have much structure.
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
Takeuchi TL8R2 (A47477)
Takeuchi TL8R2...
20 Ton Hydraulic Bottle Jack (A55787)
20 Ton Hydraulic...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A53422)
2017 Ford F-550...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
