Hardie Cement Backer Board Installation Question
   / Hardie Cement Backer Board Installation Question #11
you are not addressing the most critical piece of information for floor tile installation......what is the deflection of the floor joist?....that will be calculated by the clear span of the joist....the joist size......the joist material.....the joist spacing...whether the plumber notched any joists and what size and location of the notches......and whether the bathroom is located on the first floor or the second floor of a residence.....tile is a very unforgiving material when it comes to bending and although you may not notice a 1/4" deflection on the floor the tile sure will......I suspect this is why all the installers are spec'ing 1/2" to get a little extra stiffness to the floor.....installers want to do the job once and be done with it.....the tile manufacturer should have the installation specifications required and you can also look at the tile council of america for their installation handbook......Jack
   / Hardie Cement Backer Board Installation Question #12
I sure have liked that new lighter advantech board that came out to replace cement backer board.
   / Hardie Cement Backer Board Installation Question #13
I have done several tile floors with embedded heat and quick-set. Always used 1/2" Hardie glued and screwed. Never had a problem w/cracking tile. As was mentioned, 24" joist spacing is iffy for flexing. 24" 2 X 12 joist spacing with 5/4 T&G plywood works well, less starts becoming softer. Older houses; you never know what you will find under the substrates. My current bathroom remodel revealed a large area of dry-rot where shower had leaked int the walls. Wall studs, plates, and plywood floor replacements necessary.
Ron
   / Hardie Cement Backer Board Installation Question #14
LIke jfh and Seabee said every job is different. 40 years of doing this and I still see stuff that makes me shake my head. cut up floor joists rot bad delaminated plwood {houses built in 70,s had real bad plwood delamination problem]. Old osb swelled up from years of leaking fixtures all have to be addressed before you even think of tileing. Trying to save a few bucks on 1/4 " vs 1/2" ain't going to do u any good when u have cracks in tile down the road. If floor joists r 2 ft oc I would have at least 11/2 "of sub straight . 2 many tile jobs fail from bad prep .:drink:
   / Hardie Cement Backer Board Installation Question #15
Don't forget to mud set the cement board. You also need to back butter the tiles.
   / Hardie Cement Backer Board Installation Question #16
The op corrected specs after initial post. Joists are 16" o.c.
   / Hardie Cement Backer Board Installation Question #17
I have built 4 quality houses fron scratch. 1/4 inch is fine on a 3/4 inch floor with 16” o.c.
   / Hardie Cement Backer Board Installation Question #19
I prefer the Durock to the Hardee. Easier to cut. Makes a little more mess, but I really like it.
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
17101 (A55787)
17101 (A55787)
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
