Quick Hitches Hardee E 52LT Rotary Cutter Questions
   / Hardee E 52LT Rotary Cutter Questions #1
Nacademus
Rural, Ohio
Massey Ferguson GC1720
Hello.
I picked up a Hardee 52LT Rotary Cutter, today.
Originally, the ad said it was a small 4ft cutter and only showed one photo. The seller wasn't too keen on all the specifics but I took a gamble and drove an hour and a half one way to go see it. It's a little big. I think it's going to be too big for my Massey Ferguson GC1720-which was my intended use. My friend and I both have GC1720s. He also has a Ford 2600. We figured it could be a good fit for that and went half in on it.
It's a real heavy duty unit and it's in pretty decent shape considering the age.
I really would like something smaller for my subcompact. Is there any chance in heck that this could work? I looked at some units Rural King is selling but they're so expensive and I don't think the steel decks will last on them.
Anyone have insight on my situation, or have any experience with this particular unit?
Anybody?
   / Hardee E 52LT Rotary Cutter Questions #3
I've had a Hardee for 22 years. If your tractor can pick it up, you're good to go. You don't have to use the whole width in heavy growth. Or go fast. Regulate the horsepower needed with either cutting width or speed.
I'm concerned that the width
between the pins may be too wide. I haven't test fit it yet. It just looks big.
   / Hardee E 52LT Rotary Cutter Questions #5
You can reverse the pins to the inside if too wide. Also if your 3 point is a 0 size, and the Hardee is #1, simply replace the pins to match.
I thought about that!! I wasn't sure if I could or not. That makes things a little better! I'll try it!
   / Hardee E 52LT Rotary Cutter Questions #7
Your 1720 should lift 1150 pounds at the 3 point. And it's a #1
So, I should be OK?
   / Hardee E 52LT Rotary Cutter Questions #9
yes...
Sweet. Thanks. I can't find anywhere that tells me what this cutter weighs but the loader lifted it-so I assume it's not going to weigh tooooo much
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2 piece Bale Ring Feeder (A50515)
2 piece Bale Ring...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
2015 CATERPILLAR D6K2 XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
