Hard to start
/ Hard to start #1
WOSIK1
southern california
3015hst 2005
Has anyone had a problem with a Mahindra tractor being very hard to start? I live in southern California where the weather is mild. Sometimes takes me 45mins to an hour to start my 3015 hst. Once it's running, there are no problems, and it runs full throttle for hours. I'm tired of tearing up batteries and wasting priceless diesel. thanks for any help, Jeff
/ Hard to start #2
Does the engine turn over fine?
What is the temperature at when you start it.
If you shut it off when it is warmed up, will it start back up?
/ Hard to start
cranks and cranks and cranks, even in warm(75-80f), almost catching all the time. eventually it will catch and a huge amount of black smoke pours out. after running fine for several hours, turn it off and it's hard to start again.
/ Hard to start #4
It seems to me that the problem has to be either poor quality fuel or low compression.
/ Hard to start #5
Also make sure the injection pump is ok. Crack the injectors and see if the diesel is spraying out with some pressure or if it just drips.
/ Hard to start
Do you know by any chance what the compression shoul be on a mitsu k3m motor? We tested compression, and it was good on all 3. Thanks
/ Hard to start
The injector pump seems to be good also. Cracked injectors and fuel was spraying out.
/ Hard to start #10
Change your fuel filter, and test your glow plug rail to make sure its making good contact with the glow plugs.
If all is ok there, then check your glow plug timer, its the small black box under the steering wheel, you will have to remove the wrap around black cover.
/ Hard to start #12
When you turn the key on, how long does it take for the glow plugs to turn off ?
/ Hard to start #13
The thing that puzzles me is it runs well once it is running, and at the temperatures you say you are starting it in, the glow plugs shouldn't be that critical. I had a customer who was not having trouble starting the tractor, but it started very rough and smoked a bit after it started, and would gag you out of the garage. I solved his problem by convincing him to quit using the off road diesel he was getting on the Indian reservation. He said he had always run it in his Kubota with no problems, but I proved to him that his Mahindra 2015 didn't like it.
/ Hard to start #15
I have had 2 mahindras that behaved like this.
We replaced the glow plugs and wire brushed the metal rail that bonds them together, that cured the problem.
Once they are warm, they will start easy, even with the bad glow plugs.
Are you sure you put in the correct glow plugs???
/ Hard to start
took serial# and Model # to mahindra dealer and they ordered my glow plugs from those numbers. Also, I use good diesel not red dye from reputable staions, so I don't believe it is bad fuel. My problem out here is that the dealer that sold the tractor is a horse trailer place that no longer has a mechanic that works on mahindras(he moved to Texas!) Also john deere, kubota, and massey dealers here won't touch it. I'm on my own and ready to drive it off a cliff. Hard to look at it in the yard for almost a year after spending 17k. Thanks for all your continued help, Jeff (951)236-3974
/ Hard to start
Also, I will have to test duration of the glow plug timer in a day or two as the starter seized again for the third time and is currently being rebuilt(again).
/ Hard to start #18
I feel for you. My local dealer refuses to work on Mahindras that they did not sell. Personally I don't know how a manufacture will allow this as I'd yank the agreement back so quick it they wouldn't see it coming or going.
You might call around to some independent shops and see if someone can give you a hand. Also you might try calling some diesel shops and see if they have a field mechanic etc... Good luck
/ Hard to start #19
Is the electric transfer fuel pump working? air leak? if you bleed the fuel system when it wont start does it start right up are you getting air out anywhere? there also should be a intake manifold heater for starting, Is this a turbo charged 3015 or non turbo? maybe wrong glow plugs? but
I personally own a 3015 turbo and will start almost instant even when cold (15 to 20 deg) if you dont let the glow plugs cycle.
/ Hard to start
Electric fuel pump is working fine, can't find air leak, is non turbo and air intake manifold is hot.
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2022 EZ-GO ELITE...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
