hard to get to grease fitting
   / hard to get to grease fitting #1
pyates
Shreveport, La
Kubota L3200
I have a Land Pride 1860 cutter. It seems almost impossibe to get to the grease fitting on the front of the drive shaft. Am i missing something?
Also, the manual says to grease the shaft itself periodically. How do you do that?
Thanks.
   / hard to get to grease fitting #2
Take pto shaft off,and then you can turn u-joint to reach zert. While it is disconnected slide shaft apart and spread some grease on square shaft.
   / hard to get to grease fitting #3
Also, NAPA sells a fitting for the end of your grease gun that has a slot for the zerk on the side (90 degrees) instead of on the end. You can get to a lot of zerks in tight places with one of these.
Here is one on Amazon:
[ame=http://www.amazon.com/gp/product/B000G76OMA/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000I19CF0&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1JJJ6GFAX9C5FK5HA1F5]Amazon.com: Lincoln Lubrication 5883 Slotted Right Angle 90 Degree Coupler: Automotive[/ame]
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
Titan PDG3200 Gas Powered Post Driver (A52377)
Titan PDG3200 Gas...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
