Hard starting and white smoke when accelerating
   / Hard starting and white smoke when accelerating #1
BahlSacke
New Holland 1725
NH/Ford 1725, 4600 hours, new to me about a month ago. Not sure if these two issues are related or not. If I run the glow plugs for 40 seconds (manual says there’s no timer and to run for 10 seconds, so I cycle for 10 seconds 4 times) the tractor starts up right away. If I run glow plugs for 30 seconds it takes 4-5 seconds to start. No glow plugs it takes… a really long time (30 seconds I’d guess) and will eventually start up. I only did it once, before I troubleshot the glow plugs. The glow plug light doesn’t turn on, but the glow plugs clearly do, to some extent atleast. Outside temperature doesn’t seem to make a difference (95* out today), but once the tractor has warmed up it will start right up without glow plugs.
When it starts it blows a puff of black smoke.
When I accelerate I get a puff of white smoke.
No smoke otherwise.
Other than that it runs really strong, no issues.
Changed the air filter and fuel filter with no affect.
None of the smoke or running glow plugs bothers me necessarily, but I have no idea what it means, but it certainly seems like something (or multiple things) isn’t right.
   / Hard starting and white smoke when accelerating #2
Smoke is not unusual when the engine is cold and you have a lot of hours that are unknown to you regarding prior service.
You may have a glow plug or two not functioning. Outside temp may be 95, but the engine is probably cold from the night before and is far from operating temp.
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
19200 (A50324)
19200 (A50324)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
2015 John Deere 7700A Precision Cut 100in Reel Commercial Mower (A52377)
2015 John Deere...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
