kayssupply
Platinum Member
I have a YM2210B that starts way to hard. Once it hits it will purr like a kitten. At running rpm it has good power. It will smoke to high heaven while trying to start. It has what seems to be good compression, as hard as it is for the starter to turn it over. It has zero blow by while running at all rpms. The thermal start is working, and I use the compression release while trying to start it. I have tried starting at low throttle,medium and full. It won't do anything unless it is at almost full, until it hits, and then throttle down and runs great.
It has new air filter,fuel filter, and drained and fresh fuel. Does anyone have an idea of where I need to start to make it easier to start?
