Hard starting 1952 8N
   / Hard starting 1952 8N #1
vette6t6
Fort Wayne, IN
1952 8N
Tractor has become hard to start. Once started every once in a while it acts like it's starved for fuel and will just shut off. Usually can get it started back up and it will run a while longer before repeating. This last time it happened I couldn't get it re-started. Any ideas?
   / Hard starting 1952 8N #2
Is there fuel in the sediment bowl, carburetor? Does it have spark? Bad coil will cause it to shutoff, but usually won't start again for an hour or better.
Tractor Tech- The sediment bowl is full. Same with carb. I removed the plug from underneath the carb and lots of gas ran out. By removing sparkplug and laying on block, definitely has spark. Tractor does have electric fuel shutoff solenoid added. I wonder maybe there is a loose wire? Don't think so though. Not sure about the condition of the coil or even how to check it.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Bush Hog 10' Pull Rotary Mower (A50774)
Bush Hog 10' Pull...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
