Hard starting 1952 8N
   / Hard starting 1952 8N #1
vette6t6
Fort Wayne, IN
1952 8N
Tractor has become hard to start. Once started every once in a while it acts like it's starved for fuel and will just shut off. Usually can get it started back up and it will run a while longer before repeating. This last time it happened I couldn't get it re-started. Any ideas?
   / Hard starting 1952 8N #2
Is there fuel in the sediment bowl, carburetor? Does it have spark? Bad coil will cause it to shutoff, but usually won't start again for an hour or better.
Tractor Tech- The sediment bowl is full. Same with carb. I removed the plug from underneath the carb and lots of gas ran out. By removing sparkplug and laying on block, definitely has spark. Tractor does have electric fuel shutoff solenoid added. I wonder maybe there is a loose wire? Don't think so though. Not sure about the condition of the coil or even how to check it.
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
Kubota B2601 (A50120)
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
CUSHMAN HAULER PRO GAS GOLF CART (A51243)
CUSHMAN HAULER PRO...
