Hard start D120
   / Hard start D120 #1
frogpond
Snohomish WA
Kubota BX25D
I have had the compression release replaced twice on this pos B&S Intek engine, and I think it's okay at this point. However, when starting, the engine whines for a while, like the starter is straining, about 5-10 seconds, then suddenly cranks and usually, but not always, starts and runs fine. Sometimes it backfires before starting. I took the battery to Napa, and it checked out okay. I keep a trickle charger on it, anyway. I have checked the valve lash, and I think they are okay. Any ideas appreciated!
   / Hard start D120 #2
Sounds like the compression release is still the culprit.
   / Hard start D120 #3
Try turning the engine by hand until it just gets past compression and then try starting the engine. If turns over now points towards the POS compression release failure again.
Supposedly Briggs improved the design but I have no hard data proof of that.
   / Hard start D120 #4
Does this sound what you did? Snug- .003" Intake (lower valve), .005" Exhaust. Set when the piston is 1/4" past top dead center after the Intake valve closes. Use a dowel, pen through the spark plug hole to check the position of the piston.
   / Hard start D120
I'll check the valves again. Thanks!
1 pallet of power tools (A50860)
1 pallet of power...
Payment Terms (MUST READ) (A50774)
Payment Terms...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A50397)
2018 Ram 5500...
2011 Chevrolet Impala Sedan (A48082)
2011 Chevrolet...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A50505)
2018 KENWORTH T680...
