Hard Hydraulic Line Snapped
   / Hard Hydraulic Line Snapped #1
CPM
Bronze Member
QLD
Looking
Hi All
Got a new Changfa a couple of days back and whilst doing some light grass slashing, hydraulics failed on the bucket as I was lifting it to see ahead of my track.
I noticed a funny smell, stopped, looked on the ground and saw a pool of green/yellow liquid forming underneath.
After a closer look, it appears that a hard hydraulic line has sheared straight through. There's no bends or kinks, just a clean snap.
I'm hoping this picture gets attached... 20130329_111117.jpg pic should be rotated 90 deg right.
It looks like a pretty vulnerable position for the pipe but I couldn't see anything underneath that would cause the pipe to snap like that.
Is it normal to run pipes like this? Is there a better solution when trying to get it fixed?
All thoughts and comments welcome.
Bit disappointing for new machine but I've never had one before, so perhaps this is life?!
   / Hard Hydraulic Line Snapped #2
You might be better off cutting the tubing off leaving a bit for these to grab and using something like this tube compression fittings - Hydraulic Supply Co. and adapting to a conventional hydraulic hose. Or removing the tube completely and replacing the complete run with hose, hard to tell without an overall view.....Mike
Thanks Mike, I got the steel tube part replaced in the end. It enabled me to better position the hose and run it in a safer way.
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
