Hard freeze, now hydraulic leak on B7100
   / Hard freeze, now hydraulic leak on B7100 #1
Bluelick
Kentucky
Kubota B7100
Hey folks,
We have had some very cold (for us) weather here in Kentucky over the last week, -4 one night, -2 another. Yesterday I saw a stain of fluid on the ground under my B7100 in front of the mowing deck, and a drip coming off the bottom of the engine. I put some newspaper there to get a better look at what's coming out. It seems clear although tinged with black grit, probably from running down the engine. I'm assuming it's hydraulic fluid. I don't know what would have caused this from cold temps, any thoughts?
Thanks!
Bluelick
   / Hard freeze, now hydraulic leak on B7100 #2
Hey folks,
Thanks!
Bluelick
One possibility is there was some water trapped in a fitting etc. that froze and expanded causing a small crack etc...
   / Hard freeze, now hydraulic leak on B7100 #3
It would appear most hydraulic fluid appears to have a freeze point of -40F. We were down to -15 ambient air temperature a few days ago and no ill effect on my hydraulic fluid. I would suspect there was some water somewhere that froze and caused trouble. Possibly an O ring or something cracked.
   / Hard freeze, now hydraulic leak on B7100 #4
Should be two hydraulic lines in that area that go to the oil cooler.
best start tracking the leak to find out where it originates. Wipe all down with a rag so it's easier to see fresh oil.
   / Hard freeze, now hydraulic leak on B7100 #5
Hey folks,
Thanks!
Bluelick
Invest in some UV leak detection equipment. Makes finding the source of a leak very easy.
You add a small packet of UV dye to the tractor system you suspect, in your case the hydraulic system.
You run the machine for an hour or twwo and then, using a UV flashlight start scanning or lighting up the underside of your tractor.
The leaking fluid will glow and it is easy to see where it originated.
Look at these youtube videos to understand how the process works and then shop around for an inexpensive system
Spectroline’s OPK-441 leak detection kit - YouTube
How To Find And Fix Car Oil Leaks - YouTube
These UV systems originated for the air conditioning industry where it was a gas that was leaking not a liquid so much harder to find.
Often, older O rings in cold weather loose their resiliency and leak but once things warm up the leak stops.
Dave M7040
Thanks all for those leads--I love the UV trick! It was warmer this week but work had me tied up and now it is going to get cold and snowy again, so this may need to wait a bit longer but I really appreciate the help!
   / Hard freeze, now hydraulic leak on B7100 #7
Is your hydraulic filter located in that area?
Check it for a swollen can or a displaced o-ring on the sealing surface.
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
LMC LOT NUMBER 143 (A53084)
LMC LOT NUMBER 143...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2023 JOHN DEERE 2032R LOT NUMBER 164 (A53084)
2023 JOHN DEERE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
