Harbor Frt gas engines
   / Harbor Frt gas engines #1
dan1948
Got a flyer today from HF, has a 5.5 HP OHV vertical shaft EPA lawn-mower use only lot # 96156 for $100. I live in hurricane country and before Katrina Briggs carb overhaul was $50 now $150. See my situation?? Can anyone comment on these engines ? Thanks Dan
   / Harbor Frt gas engines #2
I have not owned one personally but a good friend builds a lot of racing go cart engines. A rule change to allow OHV engines has moved him away from 5.5 HP B&S engines to Hondas and now the Chinese Honda knock offs. He has bought more than 20 of them in the last year from Harbor Freight. He is a very particular man and I was initially really surprised how well he likes them. So far he has had as good of luck with them as anything he has used. I think that speaks pretty highly given the fact that the first thing he does to the majority of these engines is take the governor out of them and bolts on a carb to burn methanol. He has a dyno in his shop and regularly tunes these motors to produce more than 20 HP @ +9000RPM. I know on the B&S engines, the higher tuned ones used aftermarket rods, cams, flywheels and pistons and I would guess his high HP Chinese ones do as well but I do know he builds a fair amount of lower tuned ones using mostly stock parts that he machines and balances.
   / Harbor Frt gas engines #3
i bought a 6.5 h.p. hf motor a month ago. runs great quiet and starts easy.i think there a good motor.
   / Harbor Frt gas engines #4
I wish they would offer a 14 hp horizintal one I could use in my Cub Cadet 1450 they want over 1000.00 for a motor for it now
   / Harbor Frt gas engines #5
have had one on a water pump for a few years now runs great
   / Harbor Frt gas engines #6
I have similar engines on a water pump and log splitter and one of my friends had one on a pressure washer. The only thing I have noticed is they seem to run hot -- very hot. At first I was concerned but it has not seemd to affected them. I do change oil frequently however:eek::eek:
   / Harbor Frt gas engines #7
They offer 13hp...isn't that close enough?;)
When on sale you could buy 4 of them for $1000:eek:
   / Harbor Frt gas engines #8
I didn't know they offered a 13hp?? guess I'll grab a 20% coupon and go visit them..Thanks
   / Harbor Frt gas engines #9
They have them on sale regularly for $299 so with 20% off that you are down under $250...pretty good deal.
   / Harbor Frt gas engines #10
I bought one of the 6.5 hp motors for a sickle bar mower that needed an engine. It bolted right up, same holes, bolts, pulley and cables.
I have used it a lot and it starts easier than anything I have. It is quiet, smooth and more power than I need. So far, so good and I would buy another if I need one.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
