Harbor Frt gas engines
   / Harbor Frt gas engines #1
dan1948
Got a flyer today from HF, has a 5.5 HP OHV vertical shaft EPA lawn-mower use only lot # 96156 for $100. I live in hurricane country and before Katrina Briggs carb overhaul was $50 now $150. See my situation?? Can anyone comment on these engines ? Thanks Dan
   / Harbor Frt gas engines #2
I have not owned one personally but a good friend builds a lot of racing go cart engines. A rule change to allow OHV engines has moved him away from 5.5 HP B&S engines to Hondas and now the Chinese Honda knock offs. He has bought more than 20 of them in the last year from Harbor Freight. He is a very particular man and I was initially really surprised how well he likes them. So far he has had as good of luck with them as anything he has used. I think that speaks pretty highly given the fact that the first thing he does to the majority of these engines is take the governor out of them and bolts on a carb to burn methanol. He has a dyno in his shop and regularly tunes these motors to produce more than 20 HP @ +9000RPM. I know on the B&S engines, the higher tuned ones used aftermarket rods, cams, flywheels and pistons and I would guess his high HP Chinese ones do as well but I do know he builds a fair amount of lower tuned ones using mostly stock parts that he machines and balances.
   / Harbor Frt gas engines #3
i bought a 6.5 h.p. hf motor a month ago. runs great quiet and starts easy.i think there a good motor.
   / Harbor Frt gas engines #4
I wish they would offer a 14 hp horizintal one I could use in my Cub Cadet 1450 they want over 1000.00 for a motor for it now
   / Harbor Frt gas engines #5
have had one on a water pump for a few years now runs great
   / Harbor Frt gas engines #6
I have similar engines on a water pump and log splitter and one of my friends had one on a pressure washer. The only thing I have noticed is they seem to run hot -- very hot. At first I was concerned but it has not seemd to affected them. I do change oil frequently however:eek::eek:
   / Harbor Frt gas engines #7
They offer 13hp...isn't that close enough?;)
When on sale you could buy 4 of them for $1000:eek:
   / Harbor Frt gas engines #8
I didn't know they offered a 13hp?? guess I'll grab a 20% coupon and go visit them..Thanks
   / Harbor Frt gas engines #9
They have them on sale regularly for $299 so with 20% off that you are down under $250...pretty good deal.
   / Harbor Frt gas engines #10
I bought one of the 6.5 hp motors for a sickle bar mower that needed an engine. It bolted right up, same holes, bolts, pulley and cables.
I have used it a lot and it starts easier than anything I have. It is quiet, smooth and more power than I need. So far, so good and I would buy another if I need one.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
