Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,221
Since I'm in my shop today, can't say enough good things about my hf 6" cross slide drill press vise, I believe it may have been discontinued? definitely not precision engineered for all the machinist folks it has some play in it and with spindle runout on my hf drill press I center punch everything anyway. It holds everything I've drilled in including using a hole saw accurately for my projects and doesn't send your work flying. Notice grade 8 washers and bolts cause the flange holes don't line up.
   / Harbor Freight Tools that don't suck #15,222
I believe it is NLA. Like the 12" diameter flat face abrasive grinder. Discontinued as well. I have one and it's a beast. Weighs around 70 pounds and the motor has some balls too. Get my PSA discs from MSC, not HF however.
   / Harbor Freight Tools that don't suck #15,223
I see it has adjustable Gibs to remove the slop.....
   / Harbor Freight Tools that don't suck #15,225
Since I'm on a harbor freight kick, the bench top tubing bender is handy had it for over 10:years, it has several dies for radiuses and one to bend flat stock notice cheater bar, I've used it for bending light guards and built a few rear racks using both steel and aluminum tubing.
   / Harbor Freight Tools that don't suck #15,226
Wouldn't grease make it fall off even easier? I'll sometimes wedge a small piece of paper in there which helps somewhat.
I do wish they had stronger magnets on them. Barely enough to hold the light to something, falls right off on something that moved/vibrated.
When did HF do free batteries? Don't ever remember seeing that.
HF had free batteries with coupon and additional purchase. When coupons were discontinued, free batteries and free other things all went away (maybe around the time covid came… not sure of time frame). I stopped going much to HF when this came about… but then I seem to have a good stock of most consumables and tools on hand.
   / Harbor Freight Tools that don't suck #15,228
Got two of them. Can't beat the price. Come in handy with the magnetic back. 😁
Dang! I was just up near my closest one yesterday. I was thinking of stopping in, but didn't.
It's 40 miles away, so not worth a special trip. I have three of those flashlights already. Work great.
   / Harbor Freight Tools that don't suck #15,229
I remember them being on sale with coupon but never free. The orange & black Thunderbolt alkalines aren't too bad, though they don't have the capacity for higher draw items like a camera. OK for remotes, flashlights, clocks, portable radios, etc. Don't think I've ever had one leak.
Have they put stronger magnets on them now? Ones I have will barely hold the weight of the light, don't directly fall off, but will work their way down whatever you attach them to. Most of the ones I have use the individual LEDs, not the newer ones with the COB ones.
   / Harbor Freight Tools that don't suck #15,230
Not sure since they are new to me. They have both a beam and a small flood light. Mine seem to have a fairly strong magnet.
VERMEER BP7000 BALE PROCESSOR (A58216)
VERMEER BP7000...
Clemco 2020 Portable Sand Blasting Machine (A55973)
Clemco 2020...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
EXCAVATOR RIPPER (A58216)
EXCAVATOR RIPPER...
