Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,211
Free is always best in my opinion. I bought one of those Braun rechargeable LED trouble lights a while back on sale (ITC) and it's ok. The hinge on the light bar is sloppy now and no way to tighten it up that I can see and the run time isn't that long either. Cannot give it a 10, maybe an 8 at best. Recharges via USB but be aware it requires a mini USB plug.
The Bauer cordless blower comes with a concentrator snout that really directs the airflow. It really 'blows'....lol...and it's a 'tool only' deal so it was pretty cheap. Think I might buy a second one today.
   / Harbor Freight Tools that don't suck #15,212
Put a little grease on it might hold your socket on better if you don't mind getting your hands a little dirty. It makes me feel anyway, like I did something besides sit behind a computer, pushing papers. 😂
Wouldn't grease make it fall off even easier? I'll sometimes wedge a small piece of paper in there which helps somewhat.
I can. 3 screws.
I've maybe dozens of them hanging all over. used to put the free batteries in them for replacement.
I do wish they had stronger magnets on them. Barely enough to hold the light to something, falls right off on something that moved/vibrated.
When did HF do free batteries? Don't ever remember seeing that.
   / Harbor Freight Tools that don't suck #15,213
Nope it helps it stick on the anvil in my experience until you get a real stubborn bolt and it gets real warm than the grease just melts away like butter lol.
   / Harbor Freight Tools that don't suck #15,214
I u
I use an oversized blow gun it disperses the air enough so it doesn't bend the rad fins, works for me.
   / Harbor Freight Tools that don't suck #15,215
Not had overly good results from the HF cheapo batteries. Not much life in them in my opinion.
On a better note, couple years ago I bought the HF 10 ton hydraulic 3 arm gear puller to remove rusted on disc brake rotors. It's a godsend. It's a bit cumbersome to get on (really takes 2 people) but once it's on, I guarantee it will pull any rusted on brake rotor or stuck drum with 3 or 4 quick pumps of the hydraulic ram. If it don't pull it, it will break the stuck rotor in two and then it will come off. I've used it on harmonic balancers on diesel engines too. Makes life a whole lot easier as in no beating them apart now which is really detrimental to the suspension parts. Comes in a nice blow molded case too.
   / Harbor Freight Tools that don't suck #15,216
I u
All well and good at the shop (and I do that as well) but in the field, the handheld Bauer blower works for me. I use it on the square bailer knotter stack as well to remove the chaff build up that causes missed bales. Hay chaff is always an issue when bailing and it would take a heck of a long air hose to get a blow gun in the middle of a hayfield...lol
   / Harbor Freight Tools that don't suck #15,217
The hf central forge fluted extractors are ok I've had this kit for years, drill bits that came with them are garbage, finally broke a extractor I won't discuss the four letter words and drill bits I destroyed in attempting to extract the extractor. Finally a older more knowledgeable person led me to reverse thread drill bits for extraction purposes. Definitely don't trust hf bits for that.
   / Harbor Freight Tools that don't suck #15,218
Off topic but reminds me of using an old grove crane used to pull boats and docks it had an air leak at a boat yard I worked at had to run 500' of air hose connected to a standalone compressor which was connected to crane down a concrete wharf in order to prevent all the brakes from locking up. That's OSHA approved right?? 😂 Side note, I will not discuss the noises the pivot bearing on the turret would make. however I wore a life jacket when I was pulling the levers and was always ready to bail in a moments notice. 😂
   / Harbor Freight Tools that don't suck #15,219
I really like mine👍 had it for a long time now was a set of three I believe HF no case though nice you can take arms off interchange components reverse them etc.
   / Harbor Freight Tools that don't suck #15,220
I have an (expensive) set of Snap On spline drive extractors. I like them a lot. Don't use any HF bits, only Cleveland Twist.
IRanch High-End Mini Golf Cart (A57149)
IRanch High-End...
36in Digging Tooth Bucket Excavator Attachment (A56857)
36in Digging Tooth...
SCREENER (A58214)
SCREENER (A58214)
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
Skid Steer 43" Disc Mulcher (New/Unused) (A59225)
Skid Steer 43"...
