Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,161
The 2 ton Pittsburgh hf cherry picker is good, had it for 4+ yrs no problems I did buy the hf air over hydraulic long arm jack for it, has worked flawless as well.
One-ton version here. Works great. Recommended.
   / Harbor Freight Tools that don't suck #15,162
I'd be curious to know how well the hf icon line of snap/ retaining ring pliers are? Personally I used to hate removing snap rings had a drawer full of cheap ring pliars best one I had was a cheap long nose needle nose one I ground down and bent it to work I eventually broke it on a L 2850 front end rebuild, went out spent some money on a knipex kit now I laugh and look forward to removing/ installing those rings.
   / Harbor Freight Tools that don't suck #15,163
I bought the large Icon snap ring pliers to remove pin retainers on the TLB- haven't tried them yet though. I gave up on the lower end snap ring pliers HF sells.
These large pliers have some weight and seem to be well made.
If any more problems I will be replacing with some more Klein tools.
   / Harbor Freight Tools that don't suck #15,164
5 years later, my bauer 70lb jackhamer from HF that I bought for $400, runs off 15a electric, is still going strong. It has been run for hours on end and there has never been an issue. It has a bit of surface rust and some areas the sun is bleached the plastic, but it has always gotten the job done.
   / Harbor Freight Tools that don't suck #15,165
Care to share which Knipex set you bought?
   / Harbor Freight Tools that don't suck #15,166
and you can run it with only one hand? Wow impressive! 😉
   / Harbor Freight Tools that don't suck #15,167
Sure can't any more I've had them almost a decade, bought from a dedicated tool supply website
   / Harbor Freight Tools that don't suck #15,168
The medium/larger sized ones with the tips going at 45 and 90 degrees are used the most/ for both internal and external rings
   / Harbor Freight Tools that don't suck #15,169
How about those wire strippers next to them? Look like HF to me..
   / Harbor Freight Tools that don't suck #15,170
To the right is a cheaper cv boot banding tool back of the drawer is a reversible channel lock retaining ring tool with interchangeable tips, good idea bad design imo there's a really cheap hf orange handle retaining ring tool and I think theres still a northern tool brand ring tool pliars, and my old broken homemade one. Really need to clean that drawer out again 😂.
Massey Ferguson 9250 (A56436)
Massey Ferguson...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
1997 Ford E-250 Cargo Van (A56858)
1997 Ford E-250...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
Pneumatic Grease Can w/Chevron Delo Starplex EP 2 (PARTIALLY USED - AIR HOSE REEL NOT INCLUDED) (A59076)
Pneumatic Grease...
